Renato Posted October 13 Posted October 13 Not sure if it's an issue but I see the light on port 1 with Lowe intensity than the other ports does that means something? Image 1: pc1 connected to port 1 and pc 2 to port 2 Image 2: pc 1 connected at port 3 and pc 2 still on port 2 both have same intensity The bright is different comparing port 2 and 3 that comparing port 1 and 2 Also internet light is low not as bright as others not quite sure what it means Thanks in advance
Administrators Netduma Fraser Posted October 14 Administrators Posted October 14 No it doesn't mean anything, no cause for concern!
