catalin Posted October 11 Posted October 11 Hi, the latest xr1000 update is really frustrating me recarding the WIFI..i'm gettingĀ frequent disconnect's . I tried everything possible..but doesent work
Administrators Netduma Fraser Posted October 11 Administrators Posted October 11 In Settings give each device a reserved IP address in DHCP then reboot the router from the interface and see if it happens again please. Also: Disable SmartBOOST, use 2.4GHz for devices/applications you want more stability on - connect to 5GHz specifically for speeds Use a WiFi analyzer to find the least congested channel and change to that Ensure the router is in an elevated position - not on a metal surface Ensure there aren't any electrical / wireless devices e.g headphones etc within close proximity ~3 feet if possible Set the antennae to this position _ | | _
