majed7sr Posted July 12 Posted July 12 Hi, I’m having an issue updating my Netgear XR1000. Current firmware: 1.0.0.78_1.0.65 I downloaded the latest official firmware (XR1000-V1.0.2.86_2.1.40.chk) from the Netgear website. Updating through the web interface always fails with a firmware update error. I also recovered the router successfully using nmrpflash, but after recovery it still boots into 1.0.0.78 instead of 1.0.2.86. The router works normally, but I cannot upgrade to any newer firmware. Has anyone experienced this issue before? Is there a required intermediate firmware version, or is this a known problem with the XR1000? Thank you.
Administrators Netduma Fraser Posted July 13 Administrators Posted July 13 You're on the beta where there are issues getting off of it, you'll have to try this version first, if you can upgrade to it then you can upgrade from there https://forum.netduma.com/topic/60122-new-xr1000-beta-firmware-dumaos-33688-upgrading-fix/
majed7sr Posted July 13 Author Posted July 13 Hi Fraser, I have tried everything listed in this topic, but unfortunately I still cannot upgrade. Here is what I have done: Rebooted the router Factory reset Used routerlogin.net/adv_index.htm Used an Incognito window Tried from a different browser Tried from the Nighthawk mobile app Successfully flashed XR1000-V1.0.2.84_2.1.39.chk using nmrpflash (the flash completed successfully and the router rebooted) After every attempt, the router always boots back to: Firmware: 1.0.0.78_1.0.65 (DumaOS 3.3.688) The upload completes, the router reboots, but the firmware version never changes. My router is XR1000 v1. Is there anything else I can try, or could this be a bootloader/firmware issue? Thank you.
Administrators Netduma Fraser Posted July 15 Administrators Posted July 15 it doesn't work for everyone, we are waiting for NTGR to provide a solution
