FourFingersOfFun Posted June 5 Posted June 5 Keep getting this error everytime I try to login to the router on my PC, I have rebooted the router and PC multiple times and even unplugged the router and waited a few mins before plugging back in, also "re upgraded" the firmware to the early access version 1147 that it already was on and that seemed to do nothing at all. Can't even login on the mobile app either, just says error occurred everytime I hit login. Really dont want to factory reset as that means I'd have to redo a ton of settings all over again and I cant remember what they all are currently nor do i have a way to see what they are right now since i cant get the interface to load properly at all Diagnostic report is here diagnostic-report-2026-06-05T02_40_03.316Z.json
Administrators Netduma Fraser Posted June 5 Administrators Posted June 5 I think you will need to factory reset, especially if you're getting that on this latest version which is overall way more stable as it's likely gotten itself into a weird state that won't clear otherwise or you could downgrade back to your previous version and it may stop.
