steven101 Posted March 15 Posted March 15 hi i am looking to switch isp to youfibre but dont want to use there router but been told they dont use pppoe to conect to there network is there a way around this to get my r3 to conect to there ont and work without there router as i am not wanting to have to use there router
Administrators Netduma Fraser Posted March 15 Administrators Posted March 15 You don't need PPPoE to connect the router to their ONT, you can just connect them and it should work unless they've specifically put measures in place to ensure you use their router connected to the ONT. You can just connect the R3 to their router otherwise. steven101 1
steven101 Posted March 15 Author Posted March 15 I have been reading online a need to clone the mac address from there router so must be locked for there routers anyone else on here tried to connect to youfibre with there r3
Administrators Netduma Fraser Posted March 15 Administrators Posted March 15 You can put that router MAC address into the R3 if needed, if that's the only thing they check for then it should work. Most likely but I couldn't say for certain or tell you who it could be
