Atzenkeeper500 Posted December 19, 2025 Posted December 19, 2025 Hey there, I received my R3 yesterday, everything seems to be fine. I have Gigabit Cable Internet from Vodafone. There own Speedtest says the Modem get´s around 1.1 Gigabit. In my R3 Speed Adjustments I can only enter 999 or less and it will be saved. If I try 1000, 1050 or 1100 it don´t get saved. Is this normal?
Administrators Netduma Fraser Posted December 19, 2025 Administrators Posted December 19, 2025 You should be able to put 1000 in but you won't be able to go higher than that as that's the maximum the ports cover
Atzenkeeper500 Posted December 19, 2025 Author Posted December 19, 2025 Alright, thank you - No Big Difference:) Netduma Fraser 1
