Reykc9510 Posted September 19, 2025 Posted September 19, 2025 Was moving around my living room, my R3 got damaged 2 antennas broke, and i'm only getting a hundred megabytes of speed is that because the antennas broke everything's hardwired. If so how do I get new antennas
Krush Posted September 19, 2025 Posted September 19, 2025 Français ! Bienvenue dans un monde où la barrière de la langue n’est plus un problème 2.0 traducteur automatique via ton navigateur 😉
Administrators Netduma Fraser Posted September 21, 2025 Administrators Posted September 21, 2025 On 9/19/2025 at 7:58 PM, Reykc9510 said: Was moving around my living room, my R3 got damaged 2 antennas broke, and i'm only getting a hundred megabytes of speed is that because the antennas broke everything's hardwired. If so how do I get new antennas If everything is hardwired then the wireless antenna wouldn't effect the wired speed. If you haven't changed any settings and only physical changes were made then it is very likely the ethernet cables. Swap out the cable connecting the R3 to your modem and check again. If it's still not working then grab a screenshot of the WAN & LAN Settings pages please
Reykc9510 Posted September 21, 2025 Author Posted September 21, 2025 The ethernet cable was the issue. Can I buy 2 antennas, they would damage when I was moving my things around in my house?
Administrators Netduma Fraser Posted September 21, 2025 Administrators Posted September 21, 2025 We can send new antennae if necessary, however, it is likely it's just that it's come apart instead of breaking, check the video to see if that applies + how to fix. If that's not it please provide a picture of how they're broken please antennaepop.mp4
Reykc9510 Posted September 21, 2025 Author Posted September 21, 2025 There both in 2 pieces there broken for sure. An thank you I do i send you my information to send?
Administrators Netduma Fraser Posted September 21, 2025 Administrators Posted September 21, 2025 Send a picture to [email protected] along with your order number and we can go from there
Reykc9510 Posted September 21, 2025 Author Posted September 21, 2025 Picture of what? I threw the broken pieces out.
Reykc9510 Posted September 21, 2025 Author Posted September 21, 2025 I dont have the email anymore with the order number. I can provide the serial #
Administrators Netduma Fraser Posted September 21, 2025 Administrators Posted September 21, 2025 A picture of the broken antenna is what I was after. Email with your full name and I can look up the order that way
Reykc9510 Posted September 21, 2025 Author Posted September 21, 2025 1 hour ago, Netduma Fraser said: A picture of the broken antenna is what I was after. Email with your full name and I can look up the order that way 1 hour ago, Netduma Fraser said: A picture of the broken antenna is what I was after. Email with your full name and I can look up the order that way LCheck your inbox for information. 4 hours ago, Netduma Fraser said: If everything is hardwired then the wireless antenna wouldn't effect the wired speed. If you haven't changed any settings and only physical changes were made then it is very likely the ethernet cables. Swap out the cable connecting the R3 to your modem and check again. If it's still not working then grab a screenshot of the WAN & LAN Settings pages please 2 hours ago, Netduma Fraser said: We can send new antennae if necessary, however, it is likely it's just that it's come apart instead of breaking, check the video to see if that applies + how to fix. If that's not it please provide a picture of how they're broken please antennaepop.mp4 10.7 MB · 0 downloads 2 hours ago, Netduma Fraser said: Send a picture to [email protected] along with your order number and we can go from there 1 hour ago, Netduma Fraser said: A picture of the broken antenna is what I was after. Email with your full name and I can look up the order that way
Reykc9510 Posted September 21, 2025 Author Posted September 21, 2025 My email is [email protected]. im not putting my full name in a public forum.
Administrators Netduma Fraser Posted September 21, 2025 Administrators Posted September 21, 2025 40 minutes ago, Reykc9510 said: My email is [email protected]. im not putting my full name in a public forum. I meant for you to send an email to [email protected] with your full name not provide your email and full name here. If you could still email us though please with a link to this topic and we'll go from there
Reykc9510 Posted September 21, 2025 Author Posted September 21, 2025 Yes of course doing it right now. Netduma Fraser 1
