Mehmet Posted July 22 Posted July 22 Hi Frazer. When I enable the geofilter on my R3, the Xbox NAT type isn't detected. When it does, the game feels bad, even with low ping and excellent stable ping. When I disable the geofilter, this problem disappears. How can I fix this?
Administrators Netduma Fraser Posted July 22 Administrators Posted July 22 Very likely the Geo-Filter is blocking the server used to test your NAT status. Check on the map for an icon being blocked when you run the NAT test and add it to your allow list, that should then fix it. They may have a couple of servers responsible so you may need to do it a few times to get all of them. Mehmet 1
