Oguzhan Posted March 29, 2025 Posted March 29, 2025 Hello, I want to create my own VPS server via Hetzner Cloud and set it up with the hybrid VPN feature. However, even though I made the necessary settings, my IP address on the device I am connected to is not the location I selected (e.g. Germany/Frankfurt), but my current location and my own IP address. Can you help me? thanks
Administrators Netduma Fraser Posted March 29, 2025 Administrators Posted March 29, 2025 How did you make the rule for the device you're on? Can you provide a screenshot of HVPN?
Oguzhan Posted March 29, 2025 Author Posted March 29, 2025 2 hours ago, Netduma Fraser said: How did you make the rule for the device you're on? Can you provide a screenshot of HVPN? First of all, I added the MacBook I use to my device list and only marked VPN from the services. thanks.
Administrators Netduma Fraser Posted March 29, 2025 Administrators Posted March 29, 2025 Remove the service and change to Do NOT VPN these services and see if it applies to the device
Oguzhan Posted March 29, 2025 Author Posted March 29, 2025 1 hour ago, Netduma Fraser said: Remove the service and change to Do NOT VPN these services and see if it applies to the device I've tried it, not much things changed.
Administrators Netduma Fraser Posted March 29, 2025 Administrators Posted March 29, 2025 That would be applying to the entire device so if that's not working then it will be an issue with the config/server
