Administrators Netduma Fraser Posted March 27 Administrators Posted March 27 Can you bypass the dongle and connect directly via ethernet to the router and see what speeds you get?
pyan14 Posted March 27 Author Posted March 27 1 hour ago, Netduma Fraser said: Can you bypass the dongle and connect directly via ethernet to the router and see what speeds you get? I have already bypass the dongle but the result remains the same - an error on the upload speed. I also tested using several ethernet cables.
Krush Posted March 27 Posted March 27 Does your Ethernet card handle Gbps well? If we reset the card's settings to factory settings, you may have third-party software on your PC that's blocking the test!
