PS5 can’t connect to PSN NETWORK using LAN but using Wifi it's ok
I have had a problem since day one of receiving my R3 router. My router is an R3 v4.0.540. When i connect my PS5 using wifi to the router, i can access the PSN Network and play multiplayer games like normal, but when i connect it using cable, I can’t connect to the PSN network or playing online games. If I bypass the Netduma router, i can play as usual with LAN cable connected. Please help me.
  • pyan14 changed the title to PS5 can’t connect to PSN NETWORK using LAN but using Wifi it's ok
Already change the ethernet cable. Still failed.
Check with another ethernet cable, also into a different port on the R3, can it connect then?
20 hours ago, Netduma Fraser said:
What about in a different port on the router?
Finally i found the problem.. when i do port forward on my old router it will block the cable connection from the R3 but not on wifi connection. I also don’t understand what’s happening but for the mean time i just leave it be. Btw, where should i do the DMZ, on the R3 router or my old router?
  • 2 weeks later...
Help…it happened again. It seems like the LAN ports have a problem. The upload data can’t go through to the Speedtest server. The download speed varies—sometimes it’s okay, and sometimes it’s not. I’ve tried using multiple wired cables, but the download speed remains inconsistent, and there is no upload. No issue when connected through wifi.
As requested. Fyi, sometimes it’s difficult to enter the dumaos web using wired cable but easily login when using wifi. Attached is the picture based on wifi
That all looks fine, are you directly connected via ethernet or going through a switch/extender for example?
R3 -> router -> modem ONT
router from my isp brand KAON AR2140
Modem from my isp brand ZTE
9 hours ago, Netduma Fraser said:
Did you put the R3 in the DMZ on the AR2140?
No.
35 minutes ago, Netduma Fraser said:
Do that and then try again please
Done that but still the same. Right now can’t even login into dumaos using network cables  only wifi is ok. The attached picture is the notification I received if login through cable. Yeah i tried using several cables already.
30 minutes ago, Netduma Fraser said:
What happens when you click continue anyway?
Keep on loading forever. Sometimes manage to login and sometime will be nothing except loading forever.
If you click the recovery options button on that page it should give you the option to get the logs, if you could do that please
I tried several times to get back to the recovery options page, but i couldn’t. Can i just upload the normal logs?
We need the logs from when it happens, don't worry about it, just when it happens again grab them from that page if you can
  • 3 weeks later...
It seems like the main problem here is the upload connection. Attached is the picture of the speedtest using the wired and the built-in speedtest. I tried numerous wired cables and the latest one I bought a new external LAN port to confirm it. Can I get a replacement for the R3?
Hi!
It's due to the USB/RJ45 dongle.
The white one is probably defective.
Does your ZenBook support USB 3?
4 hours ago, Fuzy said:
Hi!
I don’t think so because if I connect directly to the main router there’s no problem with it.
