Mac Posted February 5, 2025 Posted February 5, 2025 Hello. I am a complete newbie to internet protocols and the NetDuma R3 in general. Does anyone or can anyone provide a step-by-step guide to setting up the R3 to the max quality possible? Engineer installed ONT black box into wall and he said use this Cat7 cable to connect ONT to this NetDuma and input these digits provided. Did that. My ISP gave me my login details of: Username Password VLAN ID with IPv4/IPv6 He said I needed to select PPPoE A connection was established at the first time setup guide. Updated to new firmware. WiFi setup Entered manual speeds of 1GB/1GB — Only got 590GB up and 540GB down though? Cuz I’m on WiFi maybe? Ping Optimiser setup — Ping 6.4, Jitter 0.1, Loss 0 Got into dashboard ok. I haven’t touched anything besides Geo-Filter(**) , but here is what the router has given me so far. (**)Geo-Filter Custom (Just the UK). Steady Ping - Disabled Geo-Latency - On Ping Assist - 0/0 Off Strict Mode - On Fast Search - Off Home Location - My hometown Ping Heatmap I don’t think I’ll be using Ping Heatmap as I do not PC game. I use PS5. Ping Optimiser Same results as setup. Run full-test - On Ping Optimiser Mode - Expert Speed Test Bypass - Off Congestion Control Advanced - Download and Upload both 100% of 1GB Congestion Control Mode - Auto (Recommended) SmartBoost Priority Mode - Simple Enabled - On Device Manager Just added in all my devices (x10) Gaming - Top Priority Adblocker Off Settings WiFi - Fine WPA-PSK2 Guest WiFi - Off RGB - Just turned this off Hybrid VPN - Off Advanced LAN Router IP Address - Fine Subnet Mask - 255.255.255.0 - My ISP gave me one that says 255.255.255.255 so do I change this? IPv6 (LAN) - On Advanced WAN Details WAN IP and Public IP - Same digits. Is that correct? VLAN ID - Fine IPv6 - Turned on but then this caused loss of internet so turned it back off. Is that right? My ISP said I’m given IPv4 and IPv6 addresses? DNS Override - What do I put in these 4? MTU - What goes in here? MAC Address Cloning - Keep same DHCP - What goes in here? UPnP - On Port Forwarding - What goes in here? Static Routes - What goes in here? The rest looks ok I think. Speedtests done online using WiFi giving me consistent 650-700mb up and down but I’m paying for 1.2gb so is that a worry? Apologies if this is a lot to ask but any help with what to input the rest to get best max setup for gaming and speed would be very much appreciated. Thanks.
Administrators Netduma Fraser Posted February 6, 2025 Administrators Posted February 6, 2025 The ports on the R3 are 1Gbps so you won't ever see 1.2 through it. Where are you testing the speeds, on speedtest.net? The WiFi speeds are quite good, what do you get via ethernet? You don't need to worry about network settings like that unless you know what you're doing/doing something specific - it won't have an impact on your game quality. The only thing I would suggest at this stage is changing Congestion Control percentages to 70% for download/upload to start and see how you get on. You can also take a look at the wiki support.netduma.com for any further information you may need.
