Aylinka Posted January 25 Posted January 25 Hi there, Today, i wanted to use netduma again after my holiday. I noticed upon turning it on that it gets stuck on bootloop. See also video. I tried to restart it with the button on the back - without success. Tries to reset to factory settings via the pin hole - still no success. Can anyone please help me? Thank you! 20250125_160246.mp4
Aylinka Posted January 25 Author Posted January 25 After double checking.. It seems I used the wrong power supply...my bad. So the issue has been fixed. 😅 (dear power supply.. Why do you look like all other power supplies) Sentinel82 1
Administrators Netduma Fraser Posted January 25 Administrators Posted January 25 Haha easy mistake to make, glad you were able to resolve it and thanks for posting the solution! Aylinka 1
