Administrators Netduma Fraser Posted December 30, 2024 Administrators Posted December 30, 2024 That's fine, you don't need to know what it means, if you don't connect the switch but then connect other devices and then grab the logs please it will be a good comparison
mrmatthew Posted December 30, 2024 Author Posted December 30, 2024 5 hours ago, Netduma Fraser said: That's fine, you don't need to know what it means, if you don't connect the switch but then connect other devices and then grab the logs please it will be a good comparison I'm not sure what you're asking me for. That's all the log file that was there.
Administrators Netduma Fraser Posted December 30, 2024 Administrators Posted December 30, 2024 12 minutes ago, mrmatthew said: I'm not sure what you're asking me for. That's all the log file that was there. Don't connect the switch again Connect other devices to WiFi Get the log Post it here Then I can compare a working device log with a non working device log
mrmatthew Posted December 30, 2024 Author Posted December 30, 2024 Just now, Netduma Fraser said: Don't connect the switch again Connect other devices to WiFi Get the log Post it here Then I can compare a working device log with a non working device log We have dozens of devices connected to the network already, were they not in the log I already sent you? How do I get them to show up in the log?
Administrators Netduma Fraser Posted December 30, 2024 Administrators Posted December 30, 2024 1 hour ago, mrmatthew said: We have dozens of devices connected to the network already, were they not in the log I already sent you? How do I get them to show up in the log? That's the thing, they were connected already, I need entries for when they connect. Just forget the WiFi network on a few devices and then connect again and then grab the log
mrmatthew Posted January 1, 2025 Author Posted January 1, 2025 Hello, any updates from the last log I provided?
Administrators Netduma Fraser Posted January 2, 2025 Administrators Posted January 2, 2025 I'll have to pass it on to the team and wait for their conclusion I think
mrmatthew Posted January 2, 2025 Author Posted January 2, 2025 6 hours ago, Netduma Fraser said: I'll have to pass it on to the team and wait for their conclusion I think Alright. How long do you think that will take?
Administrators Netduma Fraser Posted January 2, 2025 Administrators Posted January 2, 2025 Couldn't say exactly, they won't all be in until next week
mrmatthew Posted January 11, 2025 Author Posted January 11, 2025 On 1/2/2025 at 3:17 PM, Netduma Fraser said: Couldn't say exactly, they won't all be in until next week Hey there, any update on this?
Administrators Netduma Fraser Posted January 11, 2025 Administrators Posted January 11, 2025 I haven't heard anything currently, they're looking at the unable to downgrade on the XR1000 issue right now as a matter of urgency. I'll chase them on this though Behringer-93 1
Guest Posted January 14, 2025 Posted January 14, 2025 On 1/11/2025 at 6:23 PM, Netduma Fraser said: I haven't heard anything currently, they're looking at the unable to downgrade on the XR1000 issue right now as a matter of urgency. I'll chase them on this though Why didn’t you just factory rest at the beginning? That would have sorted it surely, it's what people used to have to do. This bug goes all the way back to 2018 from what I remember. Also this router probably only gets security updates and Netgear used to check Netduma's code for compatibility, is that still happening? If not not you could have messed with the Netgear base firmware and proprietary blobs and caused an issues possibly.
Administrators Netduma Fraser Posted January 14, 2025 Administrators Posted January 14, 2025 3 hours ago, Killhippie said: Why didn’t you just factory rest at the beginning? That would have sorted it surely, it's what people used to have to do. This bug goes all the way back to 2018 from what I remember. Also this router probably only gets security updates and Netgear used to check Netduma's code for compatibility, is that still happening? If not not you could have messed with the Netgear base firmware and proprietary blobs and caused an issues possibly. Not sure I'm following with the factory reset? Are you referring to the switch or being unable to downgrade? Yes that's why it took so long to get it to this stage
