Chimdi Posted December 12, 2024 Share Posted December 12, 2024 Hello I have a Netduma R3 but I’m considering getting an Eero Max 7 as my primary router and connecting my Netduma R3 to it. My Netduma R3 will be for just gaming. How do I go about this? Thank you. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted December 12, 2024 Administrators Share Posted December 12, 2024 Connect it to the Eero as you have done with the R3 to your modem/ONT etc, then put the R3 WAN IP in the Eero DMZ and you're good to go. Link to comment Share on other sites More sharing options...
II Z IE IR O II Posted December 12, 2024 Share Posted December 12, 2024 3 hours ago, Netduma Fraser said: Connect it to the Eero as you have done with the R3 to your modem/ONT etc, then put the R3 WAN IP in the Eero DMZ and you're good to go. I'm assuming this can be applied to other routers also? I want to only use the R3 for console gaming (PS5). I currently have my setup as follows: Modem>Netgear Orbi>R3>PS5 Only issue I'm now having is a Moderate NAT. What can I do to change my NAt from moderate to open? Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted December 12, 2024 Administrators Share Posted December 12, 2024 41 minutes ago, II Z IE IR O II said: I'm assuming this can be applied to other routers also? I want to only use the R3 for console gaming (PS5). I currently have my setup as follows: Modem>Netgear Orbi>R3>PS5 Only issue I'm now having is a Moderate NAT. What can I do to change my NAt from moderate to open? Yes this applies to other routers too, just do the same thing and that should get it to open as well - if not you can then put the PS5 in the DMZ on the R3. II Z IE IR O II 1 Link to comment Share on other sites More sharing options...
Chimdi Posted December 12, 2024 Author Share Posted December 12, 2024 7 hours ago, Netduma Fraser said: Connect it to the Eero as you have done with the R3 to your modem/ONT etc, then put the R3 WAN IP in the Eero DMZ and you're good to go. Thank you. I will try this out Netduma Fraser 1 Link to comment Share on other sites More sharing options...
