L7NALMARI Posted December 3, 2024 Posted December 3, 2024 I did rest factory default , then I put IP address doumaos does not show the page get message domaos is not running I have xr 500 @Netduma Fraser @Netduma Admin xG3orG3x 1
L7NALMARI Posted December 3, 2024 Author Posted December 3, 2024 54 minutes ago, L7NALMARI said: I did rest factory default , then I put IP address doumaos does not show the page get message domaos is not running I have xr 500 @Netduma Fraser @Netduma Admin Delete it every thing work
Administrators Netduma Fraser Posted December 3, 2024 Administrators Posted December 3, 2024 What did you delete to make it work exactly? xG3orG3x 1
xG3orG3x Posted December 4, 2024 Posted December 4, 2024 Mine is doing this same thing after a factory reset.
L7NALMARI Posted December 4, 2024 Author Posted December 4, 2024 On 12/3/2024 at 6:33 PM, Netduma Fraser said: What did you delete to make it work exactly? Nothing I turn it off and wait about 2 hours then I turn it on and work the page open for set up ... now i have the same problem @Netduma Fraser
L7NALMARI Posted December 4, 2024 Author Posted December 4, 2024 17 hours ago, xG3orG3x said: Mine is doing this same thing after a factory reset. Again happen to me .. what u did to fix it
xG3orG3x Posted December 4, 2024 Posted December 4, 2024 After doing a factory reset I was able to access the router interface to perform the setup, just without the DumaOS GUI by going to http://routerlogin.net/adv_index.htm It works okay now, but still not sure why it’s happening though.
Administrators Netduma Fraser Posted December 5, 2024 Administrators Posted December 5, 2024 If needed do update via that way as it'll bypass DumaOS and any issues there that may be contributing to it not loading and give you a fresh install
