L7NALMARI Posted December 2, 2024 Posted December 2, 2024 every game i get pocket loss 2-5 I connect my xr 500 to modem( in bridge mood) ( from my isp ) i have fiber internet 500 download and 250 upload .. why always i get pocket loss ? @Netduma Fraser
Administrators Netduma Fraser Posted December 2, 2024 Administrators Posted December 2, 2024 Where are you measuring the packet loss? Do you see the same issue directly connected to your modem? Are you playing via ethernet or WiFi?
L7NALMARI Posted December 2, 2024 Author Posted December 2, 2024 7 minutes ago, Netduma Fraser said: Where are you measuring the packet loss? Do you see the same issue directly connected to your modem? Are you playing via ethernet or WiFi? 7 minutes ago, Netduma Fraser said: Where are you measuring the packet loss? Do you see the same issue directly connected to your modem? Are you playing via ethernet or WiFi? In call of duty bo6 yeah even directly bo6 have pocket loss playing ethernet
Administrators Netduma Fraser Posted December 2, 2024 Administrators Posted December 2, 2024 If you get it playing directly then it's likely nothing on your side that you can control, it could be your routing to the servers. Is better in non peak times?
TODDzillaInLA Posted December 2, 2024 Posted December 2, 2024 are you on console or pc and are you getting packet burst or packet loss?
L7NALMARI Posted December 3, 2024 Author Posted December 3, 2024 8 hours ago, TODDzillaInLA said: are you on console or pc and are you getting packet burst or packet loss? Ps4
Administrators Netduma Fraser Posted December 3, 2024 Administrators Posted December 3, 2024 Does it play better outside of peak times? Are you using the Geo-Filter to get the closest servers?
L7NALMARI Posted December 4, 2024 Author Posted December 4, 2024 On 12/3/2024 at 6:31 PM, Netduma Fraser said: Does it play better outside of peak times? Are you using the Geo-Filter to get the closest servers? Its good but why i get it ? And what to do to get out it ?
Administrators Netduma Fraser Posted December 5, 2024 Administrators Posted December 5, 2024 It's because either you're experiencing ISP congestion (lots of people in your area all using the internet at once, e.g. when they come home from school or work and so it causes congestion) or the same scenario but the game servers experiencing congestion because lots of people are playing after work/school etc.
