Wifi Connection Drops
brother_x
 Share
Hello, I have been having this problem for several days now, my Wi-Fi connection drops and it does not allow me to connect any device, only by cable, I have factory reset the device but the problem continues, I have version 4.0.219 and I have been seeing what there is another firmware but I can't find it, does that version correct this problem?
Regards.
On 10/3/2024 at 1:16 PM, Netduma Fraser said:
Do you notice any pattern in what devices are being used or the type of traffic when it happens?
I have not noticed anything strange, it is quite random, I have noticed that the internet connection drops, however the Wi-Fi connection is maintained for a few moments, now I have realized that the lights on the device remain fixed when the problem passes.
There is a newer firmware which you should try: https://forum.netduma.com/topic/57039-new-r3-firmware-dumaos-40290/
Try this:
  1. Split the bands, give 2.4/5GHz different names and apply - you'll want to connect to 5GHz specifically for speeds, 2.4 for stability
  2. Use a WiFi analyzer to find the least congested channel and change to that
  3. Experiment with the widths to see what gives better results
  4. Ensure it's in an elevated position - not on a metal surface
  5. Ensure there aren't any electrical / wireless devices e.g headphones etc within close proximity ~3 feet if possible
  6. Set the antennae to this position _ | | _
 Share
