fae7787 Posted September 30, 2024 Posted September 30, 2024 Hy guys , what is the difference between Port FOrwanding and Internet rules ?
DARKNESS Posted September 30, 2024 Posted September 30, 2024 @fae7787 Internet rules Block any apps or devices from accessing the Internet at whatever schedule you like to set it to. Port Forwarding Resolve connectivity issues by opening ports for specific devices Most secured method out of DMZ and UPNP
Administrators Netduma Fraser Posted October 1, 2024 Administrators Posted October 1, 2024 Exactly as above, Internet Rules are essentially parental type controls
fae7787 Posted October 4, 2024 Author Posted October 4, 2024 thanks , and the difference between port and port range : in port i have source and destination....so how can use it?
Administrators Netduma Fraser Posted October 4, 2024 Administrators Posted October 4, 2024 2 hours ago, fae7787 said: thanks , and the difference between port and port range : in port i have source and destination....so how can use it? If you're not sure on ports then it's probably best to select activities/apps until you know what ports you'd like to block/allow. Port would be a singular port and range would be a range like 80-100 fae7787 1
