Updated to recent firmware done factory reset ect now cant get onto interface just stuck loading if does load i then get stuck on speed test as its starts upto begin setup it wont allow me to save or anything
Hi done recent firmware update now i can tuse the duma app or nothing av got internet connection thats about to cant login using the app nor on pc have rebooted both duma & my sky routor nothing has worked on the speed test i notice it states it needs  a active connection but it is connected and test my speeds is grey out i need help please to resolve this as i cant do anything at all ...
Was just about to post the exact same thing , upgraded to 236 this morning and have the same issues as OP . Interestingly I am also on Sky !!
So far I have factory reset the R3 5 times and re booked Sky twice .   No internet connection exact same symptoms as OP
I’m having the same issues. I didn’t do any updates. It just died over night. Feels like a “bad cloud update” again? @Netduma Fraser are you guys aware?
Seems to be duma server issue or cloud issues they use router is working but ping optimizer aint and av found its causing issues like setting my upload speed to 1000mg while i do a ping test or ping opt am not changing the speeds or touching anything to make them change .. Never had issues till now but whatever they doing needs fixed asp making the device unusable as the device don't even load  or even boot into main duma menu lucky if it does took over 5 hours for mine to work rebooted reset different firmwares tested everything was the same no matter what i done
yeah I'm having the exact same issues too, I've had to factory restart it like 8 times... I even thought it could be firmware, so I down patched from the latest to 4.0.219 and that didn't help
It should be fine now, is that not the case?
no I'm still having issues, after awhile I can't access duma os and then everything losses connection in the house. I legit have to hold down the factory reset button on the router to fix it everytime
Set the MAC address manually to mirror the one on the bottom of the router and see if it's more stable then please. As we're exploring all ramifications of that changing and see if it helps please.
so, I changed the mac address in the OS to the same thats on the router and got no connection at all after rebooting the router, so I called up my isp so they could authenticate the new mac address and that still didn't work, I've tried factory resetting my router and can't get into dumaos at all now... I had to plug in my old XR1000.... my R3 does not work at all now even after factory resetting it and being on the phone with my isp for an hour
I responded to the topic you made on this so we can continue there
