Jougan Posted September 6, 2024 Posted September 6, 2024 I was wondering if allowing lower than 50% on the Congestion Control slider could be looked at. My max speed is around 910Mbps but 50% isn't enough to eliminate bufferbloat. I have to set the download speed to around 670Mbps at 50% CC for best results. So ideally 37% of 910Mbps would allow me to eliminate bufferbloat and download at full speed when nothing prioritised is going on.
Newfoundland Posted September 6, 2024 Posted September 6, 2024 Something is terribly wrong if you need to lower that amount. what tests are you running?
Jougan Posted September 6, 2024 Author Posted September 6, 2024 I have tested with both Waveform and PingPlotter. I spent a few hours while no one else was online so the results were fairly consistent. I'll attach my notes to show my tests.
Administrators Netduma Fraser Posted September 6, 2024 Administrators Posted September 6, 2024 We will be removing that cap a later date yes. I'd suggest testing with downloads while following: https://bit.ly/bufferbloat-test start with a high value e.g 95%, test, decrease 10%, test, decrease 10% etc, until you get to a value that is pretty good, then try 5% either side of that value to see if it can be improved. Important to note that Download/Upload on CC don't have to be the same value & you may have a better experience with differing values. This is more of a real world test as you're actually doing traffic you would normally do. Jougan and Bruno 2
