R2 Speed Issue
Gunganator
 Share
My ISP provided Hub recently died so had to jump onto the R2 only. My ISP speed is 900/125
Firmware ver
Wired connection Cat 6 for Both and tested on a RJ45 Advanced cable tester for continuity and shorts, still replaced with another set of two tested cables and issues persists.
Not getting the expected 900/125
Speedtest result
Enabled Traffic rules
Speedtest result with traffic rules
Network settings
Connected to IP'S ONT via PPPoE options
There I think I have covered everything you might ask me to check
please advise how to get the 900 instead of the 450 I am currently seeing on a port claiming to be 1Gbps.
You don't need those traffic rules. By the looks of it you've told the router your bandwidth speeds are 419/102 - change it to what you expect in the Congestion Control menu :menu and see if you get better results then.
Don't worry about the internal test, it's not always going to be accurate. You said your ISP hub died so what's the setup now specifically?
I've given you Early Access to try that firmware: https://forum.netduma.com/forum/144-netduma-r2-early-access/
well poo, better than no network at whilst I await the new hub.
BTW on a side note does the new R3 fix the overheating issue that caused wifi and what not to become unstable on the R2?
I fix my R2 by adding a small platform under it with a 5v USB fan :) stopped falling over all the time, hence why I haven't needed to post here for years.
 Share
