LightManeye Posted July 17, 2024 Share Posted July 17, 2024 Hi everyone, after using some months my XR700 with last DUMAOS, today the router is stucked on WHITE PAGE with DumaOS is Loading, how i could resolve this issue ? Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted July 18, 2024 Administrators Share Posted July 18, 2024 Generally for this issue, if you close the tab, reboot the router, wait 4 minutes and then attempt access it should load correctly. Link to comment Share on other sites More sharing options...
LightManeye Posted July 18, 2024 Author Share Posted July 18, 2024 Nothing, i think this router is in loop. i tried to upload the firmware XR700-V1.0.1.50.img but doesn't risolve this issue. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted July 18, 2024 Administrators Share Posted July 18, 2024 When did the issue start, after updating, changing settings etc? Link to comment Share on other sites More sharing options...
LightManeye Posted July 19, 2024 Author Share Posted July 19, 2024 Random, without having made any changes..... The router continued to work fine but I was unable to change the configuration Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted July 19, 2024 Administrators Share Posted July 19, 2024 Access using routerlogin.net/adv_index.htm or 192.168.1.1/adv_index.htm and perform a factory reset from there, wait 4 minutes then see if you can access please Link to comment Share on other sites More sharing options...
LightManeye Posted July 20, 2024 Author Share Posted July 20, 2024 Nothing happen, the same withe dumaos loading page. Link to comment Share on other sites More sharing options...
LightManeye Posted July 20, 2024 Author Share Posted July 20, 2024 From your url, i have uploaded a old firmware and then the last duma for xr700. It works! At the top right I read XR700 V1.0.1.50-626 is this correct? Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted July 20, 2024 Administrators Share Posted July 20, 2024 Ahh that's good to hear, well done, yes that's correct for the beta version Link to comment Share on other sites More sharing options...
