Leet Posted June 10, 2024 Posted June 10, 2024 Hi I keep getting lan cable not connected lan cable connected but when I swap back to my suppliers router with same cable I don't get any issues???
bbursley Posted June 10, 2024 Posted June 10, 2024 10 minutes ago, Leet said: Hi I keep getting lan cable not connected lan cable connected but when I swap back to my suppliers router with same cable I don't get any issues??? I wonder if its just a loose or bad cable? Maybe one is just not seating properly as it should and the other does. Notice this happens sometimes with cables that have that rubber grommet on them and makes it harder to push them in completely.
Administrators Netduma Fraser Posted June 10, 2024 Administrators Posted June 10, 2024 Also what device are you seeing this on? Have you tried a different cable to rule out the above?
Leet Posted June 10, 2024 Author Posted June 10, 2024 It's happening on my r2 om my ps5 il try new cables later it just seems funny that it's not happening on my Internet supplier router
Administrators Netduma Fraser Posted June 10, 2024 Administrators Posted June 10, 2024 Have you done any specific settings for the console such as DMZ, port forwarding etc?
Administrators Netduma Fraser Posted June 10, 2024 Administrators Posted June 10, 2024 Remove that, reboot the router, wait a few minutes then see if it continues please
jpzuppe Posted June 10, 2024 Posted June 10, 2024 I had the same issue. I replaced the cable with a new one and it worked after that. Netduma Fraser 1
