XR1000 | QoS Does not work
CenturyLink Fiber 1gig
Requires PPPoE
Downloaded, Manually installed newest driver "1.0.0.72_1.0.62" for XR1000 V1 and Factory Reset
QoS does not seem to be working at all for me. These speed tests are with QoS set to always, at 50% CC
That'll be due to PPPoE unfortunately and I think that'll be fixed in the next version. In the meantime if you want to use QoS you'll have to have the ISP modem/router handle PPPoE instead of the XR.
Take the PPPoE credentials you would have put in the XR, remove them, access your ISP modem/router - switch it back to router mode and enter the credentials into its PPPoE setting. Reboot the modem, wait 2 minutes, reboot the XR, wait 2 minutes and you should have internet through the XR and QoS should work.
Factory reset modem, entered PPPoE credentials, rebooted, rebooted xr1000, plugged in cables to xr1000. internet is back on and working, QoS features are working, i can access DumoOS for about 30 seconds and then i the below message
7 hours ago, Burtchnasty said:
Modem de redefinição de fábrica, credenciais PPPoE inseridas, reinicializado, reiniciado o xr1000, conectado os cabos ao xr1000. a internet está ligada e funcionando, os recursos de QoS estão funcionando, posso acessar o DumoOS por cerca de 30 segundos e então recebo a mensagem abaixo
Captura de tela 23/05/2024 170459.png
Não adianta defeito no xr 1000 mesmo meu também está assim já fiz isso não muda. Engraçado que no tp link antigo funciona de boa
4 minutes ago, Netduma Fraser said:
Can you access properly using either of these links?
http://192.168.1.1 or http://routerlogin.net
Okay i think this might have worked. When i access it directly through the IP link, it works. When i try to use routerlogin.net it gives me that error. Thanks!
 Share
