Administrators Netduma Fraser Posted May 12, 2024 Administrators Share Posted May 12, 2024 It doesn't detail the device that it's happening on. Get it from the System Information page instead and we can take a look at that, you may be missing entries otherwise Link to comment Share on other sites More sharing options...
dusky Posted May 12, 2024 Author Share Posted May 12, 2024 Does that still apply to the email logs? As the most recent ones were email logs? Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted May 12, 2024 Administrators Share Posted May 12, 2024 11 minutes ago, dusky said: Does that still apply to the email logs? As the most recent ones were email logs? Yes I would say so Link to comment Share on other sites More sharing options...
dusky Posted May 12, 2024 Author Share Posted May 12, 2024 Here's the logs from the system information page. logs 3.docx Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted May 12, 2024 Administrators Share Posted May 12, 2024 That's great thanks, In LAN Settings, set the DHCP range to start at .50, then assign reserved IP addresses to devices between .2 & .49 so they're out of the DHCP range, apply, reboot from the interface, wait 2 minutes and see if that stops the disconnects. Link to comment Share on other sites More sharing options...
dusky Posted May 12, 2024 Author Share Posted May 12, 2024 Just so I'm understanding you correctly. I'm doing this right , shown in images I attached Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted May 12, 2024 Administrators Share Posted May 12, 2024 Yes that's exactly right Link to comment Share on other sites More sharing options...
dusky Posted May 13, 2024 Author Share Posted May 13, 2024 Ipv6 still dropped out. Dropped out this morning Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted May 16, 2024 Administrators Share Posted May 16, 2024 Does Netgear allow you to create a ticket with them for this if you sign in here: http://support.netgear.com/ Link to comment Share on other sites More sharing options...
