xavy22 Posted April 27, 2024 Posted April 27, 2024 If I block it out of the game because it just wants to enter that server and not the others that I can do ??
Administrators Netduma Fraser Posted April 27, 2024 Administrators Posted April 27, 2024 Disable GeoLatency Disable PingAssist (set it to 0,0) Enable Strict Mode Disable Fast Search Then restart game or wait 10 minutes (in the lobby in the game). If that doesn't work, reboot PC/Console and it should work then.
