jumpinggemini Posted April 12, 2024 Posted April 12, 2024 I upgraded my XR500 firmware and now when accessing the web interface I'm greeted with either a "DumaOS is not running!" message, or just this loading page the hangs forever: I followed the instructions in this forum for upgrading the firmware, upgrading to the intermediary firmware version first which seemed to work fine, but then going from that to the new beta version, this has happened. I factory reset the device already and went through the initial setup but after that... right back to the described issue. What do I do?
jumpinggemini Posted April 12, 2024 Author Posted April 12, 2024 Okay so I was brought into the Duma setup process and I am now stuck on this: I did restart the router after about 10 minutes. Still on this
Gerry Wood Posted April 12, 2024 Posted April 12, 2024 Hey Boss this happen to me you're going to need to factory rest it then try the steps again. If your standerd Factory rest isn't reseting then try the 30/30/30 rule. Press the reset button for 30 seconds, unplug the router from its power source for 30 seconds, then plug it in with the reset button depressed for another 30 seconds. Hope this helps.
jumpinggemini Posted April 12, 2024 Author Posted April 12, 2024 23 minutes ago, Gerry Wood said: Hey Boss this happen to me you're going to need to factory rest it then try it the steps again. If your standerd Factory rest isn't reseting the the 30/30/30 rule. Press the reset button for 30 seconds, unplug the router from its power source for 30 seconds, then plug it in with the reset button depressed for another 30 seconds. Hope this helps. So hold the reset button, unplug the router for 30 seconds and pug it back in with the reset button pressed. Am I holding that reset button during that whole process? through all three steps?
Gerry Wood Posted April 12, 2024 Posted April 12, 2024 Yes @jumpinggeminihold the reset button the whole time. The lights will flicker and stuff igorne that just do the 30/30/30 rule and after just let go. The lights will be flickering or even off but just wait until the light go back to normal idel. May take it 30 seconds or even 5 mins just trust the procces.
Administrators Netduma Fraser Posted April 12, 2024 Administrators Posted April 12, 2024 Let us know if the above process works!
jumpinggemini Posted April 13, 2024 Author Posted April 13, 2024 16 hours ago, Gerry Wood said: Yes @jumpinggeminihold the reset button the whole time. The lights will flicker and stuff igorne that just do the 30/30/30 rule and after just let go. The lights will be flickering or even off but just wait until the light go back to normal idel. May take it 30 seconds or even 5 mins just trust the procces. Okay so I’ve done this; the power light is blinking and both Ethernet lights are solid. No internet though (on my phone at the moment). I’ve done this a couple times now and just ended up powering the router off and back on because the internet or wireless wouldn’t come back on its own (I waited for 15 minutes). This results in me going through the initial setup of the router and back to my original issue when duma os tries to load 73465971430__86747A1C-B77D-448F-850E-B7D84C6DFE69.MOV
Administrators Netduma Fraser Posted April 13, 2024 Administrators Posted April 13, 2024 I'd suggest reupgrading the firmware using the TFTP method, this bypasses the boot process and any issues there then once done do a factory reset for the freshest install possible: https://kb.netgear.com/000059634/How-do-I-upload-firmware-to-my-NETGEAR-router-using-TFTP-from-the-Microsoft-Windows-Command-Prompt?article=000059634
jumpinggemini Posted April 13, 2024 Author Posted April 13, 2024 7 hours ago, Netduma Fraser said: I'd suggest reupgrading the firmware using the TFTP method, this bypasses the boot process and any issues there then once done do a factory reset for the freshest install possible: https://kb.netgear.com/000059634/How-do-I-upload-firmware-to-my-NETGEAR-router-using-TFTP-from-the-Microsoft-Windows-Command-Prompt?article=000059634 I did try this and I fear I may be doing something wrong? In those instructions it states that once ready to push the installation file to the router, I have to reboot the device and wait for the orange power light to start blinking. The orange power light stays solid for me however up until it’s fully back up and running. I tried running the proper command iN CMD several times at various stages of it rebooting but it can’t seem to connect for whatever reason. I enabled TFTP services in programs and features so that isn’t the issue. I can ping my router fine after setting my static IP but tftp doesn’t want to cooperate…
Administrators Netduma Fraser Posted April 13, 2024 Administrators Posted April 13, 2024 I find that one to be a bit hard to do sometimes, try nmrpflash as people have more luck with that
jumpinggemini Posted April 14, 2024 Author Posted April 14, 2024 On 4/13/2024 at 1:26 PM, Netduma Fraser said: I find that one to be a bit hard to do sometimes, try nmrpflash as people have more luck with that This worked!! Thank you so much. I was afraid I was going to have to drop a lot of money for a new router. For anyone in the future researching this issue, I used the following two resources (a youtube video on nmrpflash and a github thread when I ran into an issue with it not connecting): https://github.com/jclehner/nmrpflash/issues/11 Basically if you try to use nmrpflash and get the "No response after 60 seconds. Bailing out." issue, you need to turn the router off, run the command detailed in the video to which you will get "Waiting for Ethernet connection (Ctrl-C to skip).", and then turn the router back on. It will connect upon reboot and push the firmware to your router. Thanks again guys!
Administrators Netduma Fraser Posted April 14, 2024 Administrators Posted April 14, 2024 43 minutes ago, jumpinggemini said: This worked!! Thank you so much. I was afraid I was going to have to drop a lot of money for a new router. For anyone in the future researching this issue, I used the following two resources (a youtube video on nmrpflash and a github thread when I ran into an issue with it not connecting): https://github.com/jclehner/nmrpflash/issues/11 Basically if you try to use nmrpflash and get the "No response after 60 seconds. Bailing out." issue, you need to turn the router off, run the command detailed in the video to which you will get "Waiting for Ethernet connection (Ctrl-C to skip).", and then turn the router back on. It will connect upon reboot and push the firmware to your router. Thanks again guys! That's brilliant to hear and thanks for posting the resources/solution with it too!
vlsualpurple Posted December 12, 2024 Posted December 12, 2024 mine is still stuck i need help ive tried the nmrp flash and it still says wait for duma os it could take up to 4 minutes to load
Administrators Netduma Fraser Posted December 12, 2024 Administrators Posted December 12, 2024 29 minutes ago, vlsualpurple said: mine is still stuck i need help ive tried the nmrp flash and it still says wait for duma os it could take up to 4 minutes to load I'll respond to your topic
met foxit Posted February 26 Posted February 26 Hello i am trying to flash it back to an older firmware. nmrp flash is doing it succesfully on the command line. When i enter my settings on the start screen and it is searching for the firmware. it sais it is the 1.0.0.78 firmware . What is happening..?? Can someone help me please
Administrators Netduma Fraser Posted February 27 Administrators Posted February 27 17 hours ago, met foxit said: Hello i am trying to flash it back to an older firmware. nmrp flash is doing it succesfully on the command line. When i enter my settings on the start screen and it is searching for the firmware. it sais it is the 1.0.0.78 firmware . What is happening..?? Can someone help me please Right click the page, then go to Inspect (Element), on the window that appears click on the Network tab. Then click the checkbox to disable cache. Then click and hold the browser refresh button, and click Empty Cache and Hard Reload. Then see if it loads correctly please.
eric97h Posted March 2 Posted March 2 i have a xr1000 and tried putting the setting to 5 upgraded to latest firmware turned router and modem off for a day rebooted etc and i cant get any of my raps to load and i dont wanna try this nprp method do i have any other options?
eric97h Posted March 2 Posted March 2 also why is this a constant problem with this router and softwar the raps simply never ever load its a fundemtnal problem and game breaking issue with this product
Administrators Netduma Fraser Posted March 2 Administrators Posted March 2 20 minutes ago, eric97h said: i have a xr1000 and tried putting the setting to 5 upgraded to latest firmware turned router and modem off for a day rebooted etc and i cant get any of my raps to load and i dont wanna try this nprp method do i have any other options? Why did you turn them off for a day out of interest? Did you factory reset after upgrading as that is generally recommended to clear out issues that could be caused by remnants of the previous version
eric97h Posted March 2 Posted March 2 How do I factory reset by holding the back button of the router correct ?
Administrators Netduma Fraser Posted March 2 Administrators Posted March 2 You have to hold that button for 30 seconds, release, wait 4 minutes and then access and go through the setup wizard. If you just hold the button briefly it will just reboot.
