Keep losing LAN connection but wifi connection remains
DanologyUK
 Share
My PC (which does not have a statically assigned IP) and is connected via an unmanaged switch to the router, keeps losing connection (Twice today so far).
I can connect to the router on my mobile when the PC is offline (which also doesnt have a static IP assigned) and restart the router and it then brings the connection back to my PC.
The last time it happened, i grabbed the logs. I lost access at 14:27
Is this a "known issue"?
9 minutes ago, Netduma Fraser said:
Check directly connected without the switch, does it connect normally then?
Sorry i should have said, i tried bypassing the switch and still the same after it went down this morning.
 Share
