Gil Posted February 29, 2024 Share Posted February 29, 2024 Has anyone had any issues with geofilter? I just got a R3 router and I'm having some regrets in upgrading. 😆 I had the xr1000 and I have not once had any issues. My ping stays at 25ms and I only play within my state. Now with the R3 it goes out of the radar I had chosen. I can't get it to stay in area selected. I don't know if I'm doing something wrong. Anyone have some advice? Link to comment Share on other sites More sharing options...
Luis Gomes Posted February 29, 2024 Share Posted February 29, 2024 Are you turning on Geo Latency? That might be the issue Link to comment Share on other sites More sharing options...
Gil Posted February 29, 2024 Author Share Posted February 29, 2024 Great question. Honestly don't know lol. The only thing I did was just mark the state I live in and added my ps5 to my device. Link to comment Share on other sites More sharing options...
cljackhammer Posted February 29, 2024 Share Posted February 29, 2024 I would stick with your previous router. Most of the core R3 features work properly and you will end having to disable them meaning the R3 is no better than a XR1000. Other things not working is CC with IPV6, port forwarding with IPv6 on PS5 etc. Netduma has been promising a firmware for about 2 monthes, and we don’t know specifically what’s being addressed. All we know is that they are working on a firmware that is “supposed” to address these issues. Up to this point none of the issues have been addressed besides a cpu utilization problem. Gil 1 Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted February 29, 2024 Administrators Share Posted February 29, 2024 Disable GeoLatency Disable PingAssist (set it to 0,0) Enable Strict Mode Disable Fast Search Then restart game or wait 10 minutes (in the lobby in the game). If that doesn't work, reboot PC/Console and it should work then. Gil 1 Link to comment Share on other sites More sharing options...
Gil Posted February 29, 2024 Author Share Posted February 29, 2024 I'll rest out when i get home from work. Thanks Fraser. Netduma Fraser 1 Link to comment Share on other sites More sharing options...
Gil Posted February 29, 2024 Author Share Posted February 29, 2024 Freaking keyboard. When I get home. 😆 Link to comment Share on other sites More sharing options...
Gil Posted February 29, 2024 Author Share Posted February 29, 2024 Ping optimizer not working. I rebooted my router 4 times yesterday and once just now. Link to comment Share on other sites More sharing options...
gangrel Posted February 29, 2024 Share Posted February 29, 2024 (edited) 7 minutes ago, Gil said: Ping optimizer not working. I rebooted my router 4 times yesterday and once just now. An outsourced company handles this (if I'm not mistaken). Just try it later. I've had that happen to me as well. Edited February 29, 2024 by gangrel Forgot sentence Gil 1 Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted February 29, 2024 Administrators Share Posted February 29, 2024 We are aware Ping Optimizer/Speed Test isn't 100% reliable at the moment and it's something the team are working on. Those features can still work, it just may not be every time. In the meantime best to adjust Congestion Control manually in Ping Optimizer > Advanced. Gil 1 Link to comment Share on other sites More sharing options...
Gil Posted February 29, 2024 Author Share Posted February 29, 2024 Fraser I tried those steps you told me it's still doing the same. It keeps connecting to of the zone area. My ping keeps going up. I know with the xr1000 i was getting 25 ping now its double that on my new r3. Link to comment Share on other sites More sharing options...
Gil Posted February 29, 2024 Author Share Posted February 29, 2024 35 minutes ago, gangrel said: An outsourced company handles this (if I'm not mistaken). Just try it later. I've had that happen to me as well. Thanks I appreciate the advice. Link to comment Share on other sites More sharing options...
Gil Posted February 29, 2024 Author Share Posted February 29, 2024 24 minutes ago, Netduma Fraser said: We are aware Ping Optimizer/Speed Test isn't 100% reliable at the moment and it's something the team are working on. Those features can still work, it just may not be every time. In the meantime best to adjust Congestion Control manually in Ping Optimizer > Advanced. Thanks Fraser. Really appreciate all information. Link to comment Share on other sites More sharing options...
Rossi300 Posted February 29, 2024 Share Posted February 29, 2024 Is steady ping on or off and are you using the simple or custom filter on the Geo Filter? Link to comment Share on other sites More sharing options...
Gil Posted February 29, 2024 Author Share Posted February 29, 2024 8 minutes ago, Rossi300 said: Is steady ping on or off and are you using the simple or custom filter on the Geo Filter? It's on. Link to comment Share on other sites More sharing options...
Rossi300 Posted February 29, 2024 Share Posted February 29, 2024 18 minutes ago, Gil said: It's on. It might not make a difference but turn off steady ping and only use the simple Geo Filter for now. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted February 29, 2024 Administrators Share Posted February 29, 2024 Do try with Steady Ping disabled and also use the Simple method instead of custom for filtering and see if that helps Link to comment Share on other sites More sharing options...
Gil Posted February 29, 2024 Author Share Posted February 29, 2024 57 minutes ago, Rossi300 said: It might not make a difference but turn off steady ping and only use the simple Geo Filter for now. it freaking worked. Let's gooooo! Thank you so much. Link to comment Share on other sites More sharing options...
Gil Posted February 29, 2024 Author Share Posted February 29, 2024 18 minutes ago, Netduma Fraser said: Do try with Steady Ping disabled and also use the Simple method instead of custom for filtering and see if that helps I just followed what Rossi said. It worked. Thanks either way. You all been awesome. Netduma Fraser and Alex49H 2 Link to comment Share on other sites More sharing options...
Rossi300 Posted February 29, 2024 Share Posted February 29, 2024 Glad I can help you out. If we all share what works best for us we can get the best out of the device while the Dev's are working on firmware upgrades. Gil 1 Link to comment Share on other sites More sharing options...
Gil Posted February 29, 2024 Author Share Posted February 29, 2024 12 minutes ago, Rossi300 said: Glad I can help you out. If we all share what works best for us we can get the best out of the device while the Dev's are working on firmware upgrades. Very true. Again thank you. Rossi300 1 Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted March 1, 2024 Administrators Share Posted March 1, 2024 Great to hear that, thanks for the update! Link to comment Share on other sites More sharing options...
