I just connected my new netduma r3 router to my xfinity gateway and the wifi seems to be working fine. I am attempting to use the DumaOS 4 Speed Test and Ping Optimizer but with no luck. When I use the speed test it just says my upload and download speeds are "-". and when I try and use the ping optimizer it says "DumaOS is unable to complete the Ping Optimizer process due to external circumstances." I have already tried restarting my router and modem but am still getting the same results. I would also like to note that my download speed is about 200mbps less than what I was getting before I installed the router.
Netduma are aware Ping Optimizer/Speed Test isn't 100% reliable at the moment and it's something the team are working on. Those features can still work, it just may not be every time. In the meantime best to adjust Congestion Control manually in Ping Optimizer > Advanced.
Hopefully it will be remedied in the next firmware update.
As above, if you enter the values manually it should work fine and then when you do a speedtest.net test you should get the expected speeds
