100% won't be doing anything, do 70% and see if it is any better, disable Geo-Latency and Steady Ping, then try again
Keep us posted! Disable those Geo options also
Same thing happens searching for game at higher pings it doesn't do this on xr1000 or my cell phone internet modem it only does this on the r3 specifically
From what I can tell, the Geo-Latency would be more for those trying to get servers that are kind of far away or on other continents or are searching with no Geo-Filter boundaries set as a way to keep the game from kicking people out of the lobby in case their ping went too high or something. So if you are looking for servers within +/-500 miles, you don't need it. Steady Ping will give you the look of playing at a higher ping but like it says, it creates a buffer zone for your ping but if you have a bad connection, that zone can be in flux from game to game and is generally for those who have higher that 50ms ping, or something like that. I already get low ping so when I use steady ping, it is searching for lobbies with that higher ping but then I find that I get into lobbies with higher ping players and sometimes the ping breaks the buffer zone. Playing without it, I see some occasional ping spikes but the games I'm in are played at my lower ping so the spike doesn't end up being that noticeable. The settings are to help everybody no matter where they live but not everybody needs to use all of the settings. If you are really good at the game and you keep getting into really competitive lobbies, like in COD when matching you to a lobby, it cares more about your skill during the last several games than it does the connection so the better the players in the lobby, the higher the ping, or so it seems. I'm sure somebody could have said it better and shorter so if you get this far and are confused, just ignore this.
57 minutes ago, Netduma Fraser said:
This is with Steady Ping disabled as well yes?
Yah both
Now I'm mad can't access router without a reboot now and I can't constantly reboot router I have some issues with xr1000 but not like this plus getting packet loss and lag it's not my isp either cuz I had 0 issues with xr500 and xr1000 the r3 is very good just tired of it kicking me off now and lagging and causing issues might put the r3 away till its alittle better fixed wise
ryekye, same with me regarding the constant rebooting, i ll be looking at the router on my laptop and every so often it will just say "trying to re-connect to router" and Everytime i initially turn on my xbox and try to start call of duty up it says "For this game you need to be online", i cancel that and try 2 more times, the 3rd time it usually boots up the game....never had this issue with my xr500
On 10/2/2024 at 15:40, ryekye said:
No me he encontrado con la parte de ping alto en el xr1000 solo en el r3 hasta ahora. Espero que sea una solución fácil y con la latencia geográfica en mi radio de filtro no funciona, también permite cosas fuera de mi círculo, pero el enrutador funciona muy bien. Estoy molesto por el ping alto, no importa qué juego juegue, dice que tengo entre 50 y 180 ping, cuando normalmente siempre tengo 50 o menos, como Fortnite, mi ping suele ser 22 en el servidor, ahora siempre dice 130 y bacalao cuando lo busco. Haré una búsqueda normal una vez y luego saltaré a un ping ridículamente alto como 200 para realizar la búsqueda y siempre permanecerá así de alto. Espero que sea solo un error porque nunca tuve ningún problema con el xr1000 además de la interfaz lenta y el xr500 tampoco tiene problemas. los dumaos no cargaban cosa repetitiva donde había que rehacer firmware para arreglarlo
Hello. Since yesterday it has happened to me with the Netgear xr1000, I look for a search ping of 15 and it jumps from 15 to 122 and connects me to an authentication server.
Maybe it's just a bug or something hopefully they fix it cuz the r3 is amazing when it comes to dumaos4 besides the lagging and the other part
