I have Vodaphone Fibre 2 home boardband. How do i set my netduma 2. Sorry in advance im a complete novice.
Any simple step by step guides please?
There should have been a guide included but connect an ethernet cable from the WAN/Internet port on the R2 to a LAN port on the Vodafone router. Connect to the R2 via WiFi or ethernet and go to http://192.168.77.1 to access the setup wizard/interface.
It does not let me connect to the R2 internet, just says unable to connect when i type in the password.
Its 2nd hand and i have held the reset button for 30seconds to reset the password etc.
I am unable to connect via wireless?
If it's been reset then you need to access the interface to complete the Setup Wizard before you get internet so don't worry about the no internet message. Just connect via ethernet for now to complete it
problem is i dont have ethernet port on my surface pro so only have wi-fi. When i type in the password it says unable to connect to this network but i ignore that and type the IP into the search bar but nothing
You should be able to connect to the WiFi without connecting to the internet. The default WiFi password will be the serial number on the sticker on the underside of the router
Tried the password multiple times, reset it multiple times and even tried the password conversion method.
If you have another device you can connect via ethernet I would suggest trying that way, otherwise I hate to say it but you may have bought a faulty one
