zerny92 Posted January 14, 2024 Share Posted January 14, 2024 i have since i installed the Netduma Every day Problems with my Smart Home gadgets Like sonos (arc, beam, one, etc.) and Eve thermo. When i started the Apps, the Apps don‘t find the Products. Before i have the r3 i don‘t have this Problems. Can someone help? Link to comment Share on other sites More sharing options...
Dip3hittyo Posted January 14, 2024 Share Posted January 14, 2024 I have the same problem with my R2 and it has carried over to my R3. Link to comment Share on other sites More sharing options...
zerny92 Posted January 14, 2024 Author Share Posted January 14, 2024 That is very annoying and disappointing… with all other routers there is no Problem (FRITZ!Box, speedport). i will try tomorrow to Split the wifi in 2,4 and 5 ghz and take a Look… Link to comment Share on other sites More sharing options...
Newfoundland Posted January 14, 2024 Share Posted January 14, 2024 Are your Sonos wired to a switch by any chance? Link to comment Share on other sites More sharing options...
zerny92 Posted January 14, 2024 Author Share Posted January 14, 2024 In what way? I have my netduma, not more in my little Apartment. Link to comment Share on other sites More sharing options...
Newfoundland Posted January 14, 2024 Share Posted January 14, 2024 5 minutes ago, zerny92 said: In what way? I have my netduma, not more in my little Apartment. Ah that’s fine, Sonos tends to support STP and I was just wondering if you were using switches. Link to comment Share on other sites More sharing options...
zerny92 Posted January 15, 2024 Author Share Posted January 15, 2024 I‘m absolutely annoyed… How can someone release a extensive product that is not smoothy compatible with smart home devices or something else. i could see that there were already Problems with previous routers in 2018. why don‘t you tackle a Problem Like this? Everything is becoming more and more digital and smart but the devices can‘t communicate with each other. Newfoundland 1 Link to comment Share on other sites More sharing options...
cedric108 Posted January 15, 2024 Share Posted January 15, 2024 It must be the issue of local wireless devices not being able to see each other on the same WiFi frequency. Netduma devs are aware of this issue. In the meantime, I recommend splitting the 2.4GHz and 5GHz WiFi frequencies. Place smart home devices on the 2.4GHz network or hardwire them to an Ethernet port, and use the 5GHz network for your main devices. Link to comment Share on other sites More sharing options...
zerny92 Posted January 15, 2024 Author Share Posted January 15, 2024 Thank you for your answer @cedric108. This is an absolut desaster. The Firmware has so much Problems (VLAN at Launch) etc. I can‘t wait so long till they resolve the problems. For this price i get an alternative that have not this Problems. I like how they support it but not for every price. Split the WiFi Bands made the Problem much worse. The setup doesn‘t work anymore with Sonos… Link to comment Share on other sites More sharing options...
zerny92 Posted January 15, 2024 Author Share Posted January 15, 2024 I merged the wifi Bands and now it will works… Till tomorrow… than same Like today Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted January 15, 2024 Administrators Share Posted January 15, 2024 As above, I believe it is very likely that issue so should be fixed quite quickly. Link to comment Share on other sites More sharing options...
