BL4CK OPS V3TRN Posted January 12, 2024 Posted January 12, 2024 Hi All, So my SKY Q box loses internet connection every time the R3 is re booted . I have tried assigning a fixed IP but that makes no difference , any suggestions would be appreciated
Administrators Netduma Fraser Posted January 12, 2024 Administrators Posted January 12, 2024 That's very strange, have you set it in a modem/bridge mode or anything like that?
BadBill_UK Posted January 12, 2024 Posted January 12, 2024 I have sky Q box and a sky mini box in bedroom. I have main sky Q box connected via Ethernet and have assigned both main box and mini box a static IP address and both get a connection. Then few days go by and all Ethernet devices loose connection, but reboot and all good for few more days. In device manager I also assigned them both as set top box don’t know if this helps.
BL4CK OPS V3TRN Posted January 14, 2024 Author Posted January 14, 2024 On 1/12/2024 at 7:37 PM, Netduma Fraser said: That's very strange, have you set it in a modem/bridge mode or anything like that? No I have not changed anything , and do have a fixed IP for the Sky Q box in the R3
Administrators Netduma Fraser Posted January 15, 2024 Administrators Posted January 15, 2024 I mean how the R3 would be affecting an upstream router like that I don't know, shouldn't be possible. Are there logs on the Sky hub you can look at that indicate what the issue may be?
