Bernard Posted January 12, 2024 Posted January 12, 2024 Hello, I have an R2 running r3.3.280 I have internet and the connections + routing are applied correctly. I can't access to most of the Rapp (not loaded retry in one minute) of the router and I can see only: Dashboard -> Networks Status Adblocker -> Adblock panel only System information (all panels) Network Settings -> Wan panel only On the System information: The "Installed Rapps" shows actions switch (play, pause, on startup) but they are all greyed and clicking does nothing. The logs show a tons of: Fri Jan 12 11:21:06 2024 daemon.info dnsmasq[3379]: Failed to look up com.netdumasoftware.hybridvpn object I need to travel in the next coming days and need to add a port forward before I leave the building. Reset factory is out of question and redoing ALL my complicate setup is not an option ! Help ! Bernard
Administrators Netduma Fraser Posted January 12, 2024 Administrators Posted January 12, 2024 Go to the System Information page and then in the Rapp panel menu ≡ change the retries to 5, reboot from the interface, close the tab, wait 4 minutes before accessing and see if it works then please.
Bernard Posted January 14, 2024 Author Posted January 14, 2024 On 1/12/2024 at 12:20 PM, Netduma Fraser said: Go to the System Information page and then in the Rapp panel menu ≡ change the retries to 5, reboot from the interface, close the tab, wait 4 minutes before accessing and see if it works then please. No luck... I also tried to change any possible setting on the Network Settings WAN -> General and Network panels On the system information panel using the browser dev tools and removing disable or pointer none attributes I tried to force shutting down Rapp. Seems it is only visual and doesn't work on the router settings (or lead to an error "no playicon". From time to time I can see the router is doing things, but most of the time it fails to look up to com.netdumasoftware.hybridvpn object Sun Jan 14 09:03:44 2024 daemon.info dnsmasq[11731]: Failed to look up com.netdumasoftware.hybridvpn object Sun Jan 14 09:03:44 2024 daemon.info dnsmasq[11731]: Failed to look up com.netdumasoftware.hybridvpn object Sun Jan 14 09:03:42 2024 daemon.info dnsmasq[11731]: Failed to look up com.netdumasoftware.hybridvpn object Sun Jan 14 09:03:42 2024 user.info com.netdumasoftware.geofilter: App 'com.netdumasoftware.geofilter' initialised & starting. Sun Jan 14 09:03:42 2024 user.info com.netdumasoftware.geofilter: Waiting for 'com.netdumasoftware.devicemanager' to run before starting Sun Jan 14 09:03:42 2024 user.info com.netdumasoftware.geofilter: pending subscription for package 'com.netdumasoftware.dpiclass' Sun Jan 14 09:03:42 2024 user.info com.netdumasoftware.geofilter: pending subscription for package 'com.netdumasoftware.devicemanager' Sun Jan 14 09:03:41 2024 user.info com.netdumasoftware.trafficcont: App 'com.netdumasoftware.trafficcontroller' initialised & starting. Sun Jan 14 09:03:41 2024 user.info com.netdumasoftware.trafficcont: Waiting for 'com.netdumasoftware.devicemanager' to run before starting Sun Jan 14 09:03:41 2024 user.info com.netdumasoftware.trafficcont: pending subscription for package 'com.netdumasoftware.devicemanager' Sun Jan 14 09:03:38 2024 daemon.info dnsmasq[11731]: Failed to look up com.netdumasoftware.hybridvpn object
Administrators Netduma Fraser Posted January 14, 2024 Administrators Posted January 14, 2024 Try upgrading to the Early Access firmware and see if everything loads after that
Bernard Posted January 15, 2024 Author Posted January 15, 2024 20 hours ago, Netduma Fraser said: Try upgrading to the Early Access firmware and see if everything loads after that Hello Fraser, 1/ Is it this file : DumaOS-R2-3.3.615-ee498c8daf20acd21018c54f6deb0b09 ? (found here: https://forum.netduma.com/topic/51601-new-r2-firmware-33615-smartqos-version-5/ ) 2/ Will it reset everything or keep my settings ? Bernard
Administrators Netduma Fraser Posted January 15, 2024 Administrators Posted January 15, 2024 Yes that's correct. As long as you don't factory reset settings will be preserved through the upgrade, except for QoS as QoS has changed on that version
