He4DHuNt3r_XIM Posted January 11, 2024 Share Posted January 11, 2024 I've noticed since replacing my Asus router with the R3, I'm not quite getting the full speeds anymore with a wired connection I'm guessing it's due to PPPoE? If it is, will it be fixed in a future firmware? I've already disabled SmartQoS / Smart Boost, which helped a little bit & disabling IPv6 made little to no difference. Link to comment Share on other sites More sharing options...
MikeWilde Posted January 11, 2024 Share Posted January 11, 2024 I also use the R3 with PPPoE and I'm getting about what you're getting. I think it's due to the overhead. If I connect the R3 to my gateway in DMZ I get the max speed of the Lan port. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted January 11, 2024 Administrators Share Posted January 11, 2024 Yes that'll be due to PPPoE, if possible we will try to boost the speed possible through PPPoE He4DHuNt3r_XIM 1 Link to comment Share on other sites More sharing options...
