Duma OS wouldn't open, reboot R3 to fix problems.
COD WARFARE
 Share
On 1/4/2024 at 2:07 PM, Netduma Fraser said:
If you could try with them both off that would be great to help narrow down the issue
for sure would will do both an keep you up to date if it resolves it
16 minutes ago, Matthew_D said:
hey @Netduma Fraser ive had ipv6 off an yesterday i kept smartboost off all day an today when i got on it says loading features an doesn't load still so i still have to reboot the router
Thanks for letting us know, the team are looking into it so should have a fix soon hopefully.
On 1/9/2024 at 11:48 PM, Netduma Fraser said:
Yes exactly
Swapped to another extension lead with nothing on it, so far no reboots.
Any fixes planned for the smart boost issue?
7 minutes ago, Netduma Fraser said:
New firmware should be available later today so lets see if that helps at all - it could be running out of memory caused by the high CPU usage, in which case this would fix it
Hope the xr1000 beta is coming too I'm still recovering from that surgery I had and was hoping that before February the 3.3 would come to xr1000 so I can test it on cod and fortnite and the finals!
  • 2 weeks later...
installed the firmware, no more freezing menus for me, but the router still reboots its self, may once or twice a day.
Tried a different plug and socket and it made no difference.
That's something! If your ISP modem/router has WiFi, set it up so that it is in bridge or modem mode, you can also use the DMZ. Copy the WAN IP from the R3 (found in Settings > WAN) and enter it into the DMZ function on the ISP modem/router. Disable IPv6 in LAN/WAN on the R3 and enable remote support in Settings > Troubleshooting. Then post back here from a device connected to the R3 when you've done that and we'll attempt to connect (probably tomorrow now) to enable remote logging so we can get some information when it happens.
3 minutes ago, COD WARFARE said:
Its already set up that way, I just need to enable remote support, I'll give it a few days to see if it does it again, as its not down it so far today.
Okay keep us posted and we can enable it should it happen again
Please sign in to comment
You will be able to leave a comment after signing in
 Share
