Authentik06 Posted December 24, 2023 Share Posted December 24, 2023 didnt understand have received my R3 today and setup well but in game with ea fc 24 have 60 ping must know with my xr 500 have 25 ping in the same server so have a probleme in the dashboard on netduma have host ping 21-22 buy in my ps5 having 60-55 ping showing if you have to see i will post images please help me Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted December 24, 2023 Administrators Share Posted December 24, 2023 If the ping on the Geo-Filter is low and as normally expected but the in game ping is much higher it could indicate the server is under load, in which case forcing a different server should give you a better ping. It's also possible Steady Ping is causing a higher ping, this can be disabled but you can see how it works in this video: Link to comment Share on other sites More sharing options...
Authentik06 Posted December 24, 2023 Author Share Posted December 24, 2023 Sorry for my bad English I in heatmap the ping was 40 in the nearest server but in my xr 500 when i connect to the lobby in ea fc the ping turn around 25-30 ( 5 bars) and the jitter was 0.01-10 but honestly i have played some matches i felt a difference between them the R3 was more smoothly but have a paquets loss and more jitter in it so what should be ? And whats can i do for repair this Thanks Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted December 24, 2023 Administrators Share Posted December 24, 2023 Steady Ping is likely why the game is smoother, if you disable it though does your ping decrease again? Link to comment Share on other sites More sharing options...
Authentik06 Posted December 24, 2023 Author Share Posted December 24, 2023 Not like the XR500, let me explain: on the xr500 in the geo filter the closest server is 35~50 ms away. But on the in-game lobby it shows me 30~25 max and the jitter is almost zero, the loss on the other hand is 1%. On the R3 steady ping activated or not the ping and jitter are high I will update the firmware and see what that will give Il y a 5 heures, Netduma Fraser a dit : Si le ping sur le Geo-Filter est faible et comme normalement prévu mais que le ping dans le jeu est beaucoup plus élevé, cela pourrait indiquer que le serveur est sous charge, auquel cas forcer un autre serveur devrait vous donner un meilleur ping. Il est également possible que Steady Ping provoque un ping plus élevé, cela peut être désactivé mais vous pouvez voir comment cela fonctionne dans cette vidéo : Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted December 24, 2023 Administrators Share Posted December 24, 2023 58 minutes ago, Authentik06 said: Not like the XR500, let me explain: on the xr500 in the geo filter the closest server is 35~50 ms away. But on the in-game lobby it shows me 30~25 max and the jitter is almost zero, the loss on the other hand is 1%. On the R3 steady ping activated or not the ping and jitter are high I will update the firmware and see what that will give I'm not sure how its possible for the in game to show lower than what the router is showing. Does the R3 show the same kind of ping as the 500 but the in game is also that 35-50? Link to comment Share on other sites More sharing options...
Authentik06 Posted December 24, 2023 Author Share Posted December 24, 2023 Yes the R3 showing approximately same ping on the geo filter and in game shows but the xr500 showing less then whats am seeing on the geofiltre other thing to know in my region many people play less then 20 ms on regular isp modem so whats a wrong want to know how can i exclude the paquets loss Link to comment Share on other sites More sharing options...
Authentik06 Posted December 24, 2023 Author Share Posted December 24, 2023 1 hour ago, Netduma Fraser said: I'm not sure how its possible for the in game to show lower than what the router is showing. Does the R3 show the same kind of ping as the 500 but the in game is also that 35-50? I will show you tomorrow when i go at home Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted December 24, 2023 Administrators Share Posted December 24, 2023 I would say it sounds like the R3 is making the in game ping show correctly compared to the 500. There are a lot of variables in networking so doesn't necessarily guarantee you'll receive the same ping as those in your country. Yes that would be helpful thank you. Happy Holidays! Link to comment Share on other sites More sharing options...
Authentik06 Posted December 25, 2023 Author Share Posted December 25, 2023 this is what i have in dashboard ping are 14 but in game lobby have 40-45 what should i do i have never uderstand it and look the heatmap Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted December 25, 2023 Administrators Share Posted December 25, 2023 Ah, I know what it is. It's processing delay, all games have it but not all choose to include it in their ping calculation, FC obviously does. The additional ping on top that you see in game if it's up to 30ms that is okay, anything higher than that indicates the server is under heavy load and you should try to force a different server. Link to comment Share on other sites More sharing options...
Lyuboosik Posted December 25, 2023 Share Posted December 25, 2023 On 12/24/2023 at 12:16 PM, Authentik06 said: Not like the XR500, let me explain: on the xr500 in the geo filter the closest server is 35~50 ms away. But on the in-game lobby it shows me 30~25 max and the jitter is almost zero, the loss on the other hand is 1%. On the R3 steady ping activated or not the ping and jitter are high I will update the firmware and see what that will give This is strange. I play EA FC, 15-20ms. Just geo filter on, steady ping turned OFF. because for Fifa you don't need steady ping. Been using netduma for years for competitive Fifa. If it wasn't for Duma I probably wouldn't be #1 in the world. Zippy and Authentik06 1 1 Link to comment Share on other sites More sharing options...
Authentik06 Posted December 25, 2023 Author Share Posted December 25, 2023 On 12/24/2023 at 10:16 PM, Netduma Fraser said: I'm not sure how its possible for the in game to show lower than what the router is showing. Does the R3 show the same kind of ping as the 500 but the in game is also that 35-50? I will show you tomorrow when i go at home Link to comment Share on other sites More sharing options...
Authentik06 Posted December 25, 2023 Author Share Posted December 25, 2023 18 minutes ago, Lyuboosik said: This is strange. I play EA FC, 15-20ms. Just geo filter on, steady ping turned OFF. because for Fifa you don't need steady ping. Been using netduma for years for competitive Fifa. If it wasn't for Duma I probably wouldn't be #1 in the world. How much it display in heatmap and huch mich it display in game ( the ping ) can you tell me ? Link to comment Share on other sites More sharing options...
Lyuboosik Posted December 25, 2023 Share Posted December 25, 2023 15 minutes ago, Authentik06 said: How much it display in heatmap and huch mich it display in game ( the ping ) can you tell me ? Heatmap displays 15-17 game displays 17-21. Netduma finds server veryyy fast and it is consistent ping. Never above 20. Wired connection to PS5, upnp, congestion control (always on) 70% download 99% upload, reserved ip for PS5, turn off geo latency, turn off steady ping, firmware .23. When you try these settings turn off router power button, (unplug r3 1 minute) turn off modem 1 minute. Then turn on modem and wait for it to boot up all the way, then plug in the r3 and power on. And then test the game. Link to comment Share on other sites More sharing options...
Lyuboosik Posted December 25, 2023 Share Posted December 25, 2023 38 minutes ago, Authentik06 said: How much it display in heatmap and huch mich it display in game ( the ping ) can you tell me ? Here is me playing online. My ping is lower than the ping heatmap shows. Which is good 😁 Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted December 26, 2023 Administrators Share Posted December 26, 2023 @Authentik06 have you tried the above settings that have been recommended? Link to comment Share on other sites More sharing options...
Authentik06 Posted December 27, 2023 Author Share Posted December 27, 2023 Yes i tried it and now i have in game ping 27~35 the game was smooth have some difficulties with jutter and paquets loss This is what i have so if you have any solutions please let me know Link to comment Share on other sites More sharing options...
pyroass Posted December 27, 2023 Share Posted December 27, 2023 i have the same issue. before using netduma my ping was around 30. after netduma installation i was jumping to 40-60. if i disable everything my ping is going back to the normal ping(~30) but still have some jitter, on 50ms this game is unplayable. Netduma R3: Default router: Link to comment Share on other sites More sharing options...
Lyuboosik Posted December 30, 2023 Share Posted December 30, 2023 20-48 ping is pretty decent lobbys. Jitter is going to be there anyway you look at it, it's impossible to take away all jitter. As for packet loss, that could be on your isp. Have you checked ping plotter @Authentik06? Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted December 30, 2023 Administrators Share Posted December 30, 2023 Are ALL devices connected to the R3? How is Congestion Control/SmartBOOST setup? Link to comment Share on other sites More sharing options...
Authentik06 Posted December 30, 2023 Author Share Posted December 30, 2023 7 hours ago, Lyuboosik said: 20-48 ping is pretty decent lobbys. Jitter is going to be there anyway you look at it, it's impossible to take away all jitter. As for packet loss, that could be on your isp. Have you checked ping plotter @Authentik06? What is ( ping plotter) that can you explain me ? have checked mtu too but in mw3 have no jitter all geo filter activated yesterday have catastrophic result but game has so smooth can’t explain search for logic reasons 😕 no one ! the jitter Ith xr 500 was null 0 or minim 0.01 but now more than 1% so what can i do and why the ping in duma os and the ping in game was so different 😕 Link to comment Share on other sites More sharing options...
Authentik06 Posted December 30, 2023 Author Share Posted December 30, 2023 1 hour ago, Netduma Fraser said: Are ALL devices connected to the R3? How is Congestion Control/SmartBOOST setup? Yes have my pc and some devices connected but smart boost is activated and gaming fully priority and i have found when i’am playing smart boost showing gaming was offline Link to comment Share on other sites More sharing options...
Authentik06 Posted December 30, 2023 Author Share Posted December 30, 2023 Can any one help me i’ m really frustrated have the best router in the world and didn’t improve my internet 😕 will take the controle if you want Link to comment Share on other sites More sharing options...
pyroass Posted December 30, 2023 Share Posted December 30, 2023 no chance in this moment to improve anything. just use the old router. i have the same issue. Link to comment Share on other sites More sharing options...
