Bueyako1 Posted December 24, 2023 Share Posted December 24, 2023 The light is not lightning, Useless function. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted December 24, 2023 Administrators Share Posted December 24, 2023 What device are you trying to connect to the router using WPS? Link to comment Share on other sites More sharing options...
Bueyako1 Posted December 24, 2023 Author Share Posted December 24, 2023 1 hour ago, Netduma Fraser said: What device are you trying to connect to the router using WPS? A printer, so when I press the WPS, nothing happens Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted December 24, 2023 Administrators Share Posted December 24, 2023 On the printer has you pressed/started WPS as well? Link to comment Share on other sites More sharing options...
Bueyako1 Posted December 24, 2023 Author Share Posted December 24, 2023 yes Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted December 24, 2023 Administrators Share Posted December 24, 2023 Okay I think that's probably something I'll need to pass onto the team to have a look at when they're back from the holidays. Are you able to connect the printer to the router via WiFi without WPS? What is the specific printer model? If you hold down the WPS button on the router for 5-10 seconds does that make a difference? Link to comment Share on other sites More sharing options...
Bueyako1 Posted December 24, 2023 Author Share Posted December 24, 2023 1 hour ago, Netduma Fraser said: Okay I think that's probably something I'll need to pass onto the team to have a look at when they're back from the holidays. Are you able to connect the printer to the router via WiFi without WPS? What is the specific printer model? If you hold down the WPS button on the router for 5-10 seconds does that make a difference? Canon TR4600, nothing happens when I hold the wps more than 6-10 seconds, and yes, I’m able to connect via WIFI Link to comment Share on other sites More sharing options...
PharmDawgg Posted December 24, 2023 Share Posted December 24, 2023 Where do you access the wps function in the gui. I think it would be nice to be able toggle it on or off. I don't think I have seen it. Please let me know if anyone else knows where it is located. Thanks. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted December 24, 2023 Administrators Share Posted December 24, 2023 No way to enable/disable via the interface, I'll add a request for this and get the team to look into the issue on why it's not working as well Bueyako1 and PharmDawgg 2 Link to comment Share on other sites More sharing options...
Bueyako1 Posted December 25, 2023 Author Share Posted December 25, 2023 23 hours ago, Netduma Fraser said: No way to enable/disable via the interface, I'll add a request for this and get the team to look into the issue on why it's not working as well Okay, I'm waiting for the resolution then. Netduma Fraser 1 Link to comment Share on other sites More sharing options...
Bueyako1 Posted January 1, 2024 Author Share Posted January 1, 2024 On 12/24/2023 at 7:12 PM, Netduma Fraser said: No way to enable/disable via the interface, I'll add a request for this and get the team to look into the issue on why it's not working as well Any news? Link to comment Share on other sites More sharing options...
PharmDawgg Posted January 1, 2024 Share Posted January 1, 2024 13 minutes ago, Bueyako1 said: Any news? Not yet. Netduma will be out of office until Tuesday. And with quite a few issues needing to be prioritized I am unsure where exactly it is on their list. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted January 1, 2024 Administrators Share Posted January 1, 2024 As above, due to the holidays everyone has been off, they'll be back tomorrow and they'll start to look through everything and updates may start to come out in a few days time PharmDawgg 1 Link to comment Share on other sites More sharing options...
CODZ Posted June 11, 2024 Share Posted June 11, 2024 wps still doesn't work...🤦🏾🤦🏾 Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted June 11, 2024 Administrators Share Posted June 11, 2024 3 minutes ago, CODZ said: wps still doesn't work...🤦🏾🤦🏾 We haven't made an update to fix it but we will be. Apparently from what I've been told: If you keep trying it then it can work, our estimates are that it works about 70% of the time so if it doesn't work first time there is a good chance it'll work again. Otherwise, it's quite possible depending on the device you're trying to use that it may not be compatible with WPS on the router. CODZ 1 Link to comment Share on other sites More sharing options...
CODZ Posted July 15, 2024 Share Posted July 15, 2024 was the recent update to the netduma R3 4.0.236 suppose to fix the issue?...because it didn't Link to comment Share on other sites More sharing options...
CODZ Posted July 15, 2024 Share Posted July 15, 2024 You said in your last post Netduma Fraser that "it works about 70% of the time....but it doesn't work at all...the wps light indicator on the router never comes on when i press or hold the button ...i have been doing this for awhile and it never works 🤦🏾 Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted July 16, 2024 Administrators Share Posted July 16, 2024 14 hours ago, CODZ said: was the recent update to the netduma R3 4.0.236 suppose to fix the issue?...because it didn't No it wasn't, always check the change log of the update, if it's not mentioned then it wasn't added. 14 hours ago, CODZ said: You said in your last post Netduma Fraser that "it works about 70% of the time....but it doesn't work at all...the wps light indicator on the router never comes on when i press or hold the button ...i have been doing this for awhile and it never works 🤦🏾 That's what I was told by the devs, I don't know think the light would need to come on for it to work but I will pass it on again for them to look into it more CODZ 1 Link to comment Share on other sites More sharing options...
