boothay Posted December 20, 2023 Posted December 20, 2023 I need help guys....im comming from an xr1000 to the R3 and I cannot get my mesh extender to connect to this router... any special proceedures? Im currently trying to set it up through the netgear app on my phone..... connected to the xr1000 perfectly of course... also how do i set up wifi 6?
PharmDawgg Posted December 20, 2023 Posted December 20, 2023 It is possible. I tried my Asus mesh nodes with Asus’ app and ended up having to factory reset both my mesh routers because it didn’t take. I recommend logging into the mesh nodes by way of pc and enabling access point mode. Then connect the wan port of the primary node to a lan port on the R3. Then you should be able to connect the mesh nodes by wirelessly or wired.
Administrators Netduma Fraser Posted December 20, 2023 Administrators Posted December 20, 2023 Good advice above, let us know how you get on!
Killer76 Posted December 28, 2023 Posted December 28, 2023 I have a similar issue. I have the r3 also and I put asus axe11000 into ap mode but I am getting no connectivity..for the ap.
Administrators Netduma Fraser Posted December 28, 2023 Administrators Posted December 28, 2023 12 hours ago, Killer76 said: I have a similar issue. I have the r3 also and I put asus axe11000 into ap mode but I am getting no connectivity..for the ap. If its in AP mode there shouldn't be any issues, is the R3 LAN connected to the axe WAN port?
Killer76 Posted December 28, 2023 Posted December 28, 2023 Yes it’s connected!Iried putting my xr1000 into ap mode also and I can’t get either router in ap mode to work with r3.I haven’t had any issues with previous router working with them in ap mode.
PharmDawgg Posted December 28, 2023 Posted December 28, 2023 I had to factory reset my GtAx11000pro and RtAx86u and then set them up in in AP mode by connecting an ethernet cord to each one. After making sure they were in AP mode I then connected the GtAx11000pro (Wan) to the R3 (Lan). Then I set the Ax86u into Aimesh node by way of the Asus iphone app. Then make sure you turn off the wifi on the R3. I know it is tedious but it works for me currently.
Killer76 Posted December 28, 2023 Posted December 28, 2023 Ok I will turn off WiFi and see if that will work.
Administrators Netduma Fraser Posted December 28, 2023 Administrators Posted December 28, 2023 Try the above or reboot the R3, wait a few minutes then reboot the XR, wait a few minutes and see if that works
