8 hours ago, oshookx said:
How would i get this to stop? I am sending you the logs through the messaging system.
It depends what the cause is, thank you for the logs, I'll pass that onto the team. If its what I thought it was, change the lease time to 900 minutes. If that is the cause it should happen about 3 hours later so around 4am, I would think you're probably asleep then so you won't notice if it happens again.
On 1/12/2024 at 3:23 PM, Netduma Fraser said:
When that happens could you get the logs like I mentioned above please? It could be the DHCP lease renewing potentially and taking too long for the connection to recover
Ok will do thanks
I tried changing it to 900 and 1000. It’s constantly happening. I can’t play for more than a few minutes and the hardwired connection kicks me off. My phone never disconnects from WiFi so I know it’s not my AT&T modem/router. I have dhcp setup with a static ip with my pc. I have the wan ip for my netduma setup static in my AT&T so that never changes. I’m not sure what else to try. I almost want to just return this and go back to my basic AT&T setup.
If you play without the Geo-Filter enabled do you notice the same thing happening?
I’ve tried disabling all features that affect the server I would connect to. It’s also doing it when I’m not playing. I can be in discord talking and browsing the forums and it still disconnects but my phone still works with WiFi. I tried new Ethernet cables that didn’t help. I tried disconnecting the netduma and just reconnecting straight to the AT&T modem and it doesn’t drop connection at all. I may try resetting to factory settings and see if that helps
Yeah give that a go, if it doesn't help try and get the logs when it happened along with the time it happened and that may tell us more
Tried factory resetting, that didn't help. Id say 10-15 minutes later it disconnected me while i was browsing the internet around 4:00pm eastern time. 6 hours later i got back on and its still disconnecting me. I grabbed 2 logs when it back to back disconnected me both within 5 minutes of each other. leg ending in 254 is the first log.
R3_2024-01-19T02_56_29.545Z_logs.txt R3_2024-01-19T02_55_10.254Z_logs.txt
Thanks for that, looks like port 4 is where you're losing connection, if you plug the device into one of the other ports do you see the same issue?
I don’t have anything plugged into port 4, just 1-3 my pc is plugged into 1 but it does the same thing no matter what port I plug it into
There definitely seems to be something with port 4, in LAN Settings does it show anything for port 4? I'm wondering if it's thinking port 1 is port 4 for example. If not could you just plug something into port 4 and see if it continues please?
  • 4 weeks later...
For the disconnect issue, the team are asking, when you get the issue:
  1. On command prompt, enter ping google.com and provide a screenshot of the results
  2. Then enter ping 8.8.8.8 and provide a screenshot of the results
  3. Check if the UI loads ok
  4. Are there any specific symptoms that caused it to happen? i.e. IPv6 connection, playing a game while watching a YouTube video or a teams call?
I keep getting disconnects too on cod and randomly dropped speeds on my console too I have 1gb fiber and smart qos is off and speeds keep dropping very hard it's not fun to deal with I have 1gb fiber and want my speeds to not be that low and it's not congestion control either causing that
Do all devices see the speed slow down or just the console?
all devices including pc
Could you make your own topic please? Think I'm replying to you in two different topics
