odisseas Posted November 17, 2023 Posted November 17, 2023 (edited) Hello, 👋 so I’m new here and I’m new with the extra gaming router, I always had just one but yesterday I traded my headphones for netduma r2 and I need some help to connect it to my other router which is the speedport r2. So I tried to find a similar topic but no luck except one but it didn’t helped me, so the speedport doesn’t have a bridge mode but I found the DMZ option. First of all the speed port has also a fiber connection I’m just mentioning it just in case. I also have WhatsApp or Skype if you want for easier communication Here is some pictures. Edited November 17, 2023 by odisseas Added some info
Administrators Netduma Fraser Posted November 17, 2023 Administrators Posted November 17, 2023 Hello, what is the issue you're having exactly? If you connect it according to the Setup Wizard that will get you started
odisseas Posted November 17, 2023 Author Posted November 17, 2023 Hello and thanks for the fast reply. First I don’t know which cable goes where and after that what I have to do I just go through the setup wizard and that’s it I don’t need to do anything in the other router?Â
odisseas Posted November 17, 2023 Author Posted November 17, 2023 Well I’m dump I’m so so sorry for wasting your time I managed to find the manual online and I followed up the steps and it worked so I don’t have any issues I just panicked and didn’t think that solution. Again I’m so sorry if you want I can delete the topicÂ
Administrators Netduma Fraser Posted November 17, 2023 Administrators Posted November 17, 2023 No worries at all, it's always better to ask! Did you not get a manual in the box? You should have if not but glad to hear you got it sorted!
odisseas Posted November 17, 2023 Author Posted November 17, 2023 Haha no I just traded it with my headphones and the guy who had the router didn’t find the box so he just gave it to me in a bag hahaÂ
Administrators Netduma Fraser Posted November 17, 2023 Administrators Posted November 17, 2023 56 minutes ago, odisseas said: Haha no I just traded it with my headphones and the guy who had the router didn’t find the box so he just gave it to me in a bag haha Oh I gotcha, that's fair enough! Any questions feel free to ask! odisseas 1
