I have just updated  to 1.0.3.78 firmware from Netgear link and I can’t get the DumaOS to work anymore?  The router works fine as I have used the netgear app and wifi with no problems but the dashboard when I can get it to work for a few moments only show’s settings.  I have factory reset multiple times and I have rebooted modem multiple times but can’t get the OS to show me a dashboard.  I have cleared caches in edge and chrome and still no resolution.  I continue to get this screen and it never updates. Any ideas before I trash this modem?
Posted (edited)
I forgot to include some vital information I apologize I have another wireless network running from my ISP and am running this only to use the DumaOS software for my gaming PC everything is hardwired.  I am unable to login using 192.168.1.1 as I believe that would require my ISP login information correct? Again this worked until I updated the firmware.  I was able to login using 192.168.1.123 but again no dashboard?
Edited by TatoSkinz
Forgot to add information
You've put it into AP mode, you need to switch it back to router mode to have the features
