@Netduma FraserI'd like to know best settings to connect to say Battlefield 2042, Call of Duty etc... Using latest Firmware Netduma R2 3.3.280
Give PC PlayStation Device Type in the Device Manager (if on PC)
Re-add the device to the Geo-Filter with the manual option
Even though I'm on PC it's better if I use PlayStation Device Type?
Ping Optimizer should be set 30ms - 50ms?
Also, congestion control should I set it to Auto-Enable or Always?
These few questions will help me setup my device better and thank you for your time
There are no 'best' settings that work for everyone, there are settings that we recommend you start with and then experiment from there.
Yes you should do that for the Geo-Filter but set Ping Assist to 0.
For QoS it's entirely up to you and what your network usage is like, if you want it to always apply as people are often streaming or downloading for example then always would be a good choice. If you only want it to apply when you're gaming then use auto enable. We suggest starting with 70% and going from there. You can use Connection Benchmark, specifically the Ping Under Load as an indicator of whether you need to fine tune Congestion Control - you want that graph to look as close to the Ping Test graph as possible.
