Administrators Netduma Fraser Posted July 31, 2023 Administrators Posted July 31, 2023 6 minutes ago, Cobrinio said: can you read my last post please, i was start from 100/100 cc untill 20/20 cc. i have problems with any cc What intervals were you doing, 10%?
Cobrinio Posted July 31, 2023 Author Posted July 31, 2023 4 hours ago, Netduma Fraser said: What intervals were you doing, 10%? from 100/100 cc to 20/20 cc by 5%
Administrators Netduma Fraser Posted July 31, 2023 Administrators Posted July 31, 2023 Use a local site instead of the DNS as you may not have great routing to them
Cobrinio Posted August 3, 2023 Author Posted August 3, 2023 (edited) with local site but spike lags in games continue every day... i was check every cc by 5% from 100% to 20% nothing change... Edited August 3, 2023 by Cobrinio
Administrators Netduma Fraser Posted August 3, 2023 Administrators Posted August 3, 2023 Was the above with streams/downloads being used as well or just on a quiet network?
Cobrinio Posted August 3, 2023 Author Posted August 3, 2023 5 hours ago, Netduma Fraser said: Was the above with streams/downloads being used as well or just on a quiet network? With streams or not i have bad resault everytime. i dont know what to do more....
Administrators Netduma Fraser Posted August 3, 2023 Administrators Posted August 3, 2023 1 hour ago, Cobrinio said: With streams or not i have bad resault everytime. i dont know what to do more.... It's important to know what conditions the above tests were done with, even with a local site there are a few spikes there, I think it is the routing to the servers really. Do you get the same issue if you're connected directly to the modem?
Cobrinio Posted August 4, 2023 Author Posted August 4, 2023 17 hours ago, Netduma Fraser said: It's important to know what conditions the above tests were done with, even with a local site there are a few spikes there, I think it is the routing to the servers really. Do you get the same issue if you're connected directly to the modem? All test it was with valorant play + twitch watching + youtube watching 👇This test is with ISP main modem (btw with my isp modem i have better ping in games + more stable for some reason)👇 👇valorant play + twitch watching + youtube watching👇
Administrators Netduma Fraser Posted August 4, 2023 Administrators Posted August 4, 2023 Your ping is much higher above using the modem rather than the router, maybe you're getting lag compensated, try playing with QoS completely disabled on the R2 and maybe with a stream running in the background and see if it is better
Cobrinio Posted August 5, 2023 Author Posted August 5, 2023 17 hours ago, Netduma Fraser said: Your ping is much higher above using the modem rather than the router, maybe you're getting lag compensated, try playing with QoS completely disabled on the R2 and maybe with a stream running in the background and see if it is better its higher because i am using 8.8.8.8 dns but is more stable 8.8.8.8 now from before if you check my other post. how to complete disable QoS with latest version?
Administrators Netduma Fraser Posted August 5, 2023 Administrators Posted August 5, 2023 With your speeds, it's simply not possible that you would have a completely flat ping with those 3 activities going on and no QoS. Click the TV/play icon top right > Settings then you can disable there
