NetdumaR2 Router not listed in network settings after firmware attempt
i just updated my firmware that then got stuck and since havent been able to connect or set up .. help please ive tried to reset numerous times but cannot connect to router settings ? its just showing as hidden and asks for ssid etc ? Before update network was showing as Netduma now its not appearing ?
  • Muzzman changed the title to NetdumaR2 Router not listed in network settings after firmware attempt
Did you try lan? If you upgraded to an older firmware that might be the issue older firmware's had issues losing access to ssid/unable to login using wifi lan is the only fix for those occasions
As above are you able to try accessing the router via ethernet to see if you can complete the wizard? What firmware were you on and what did you upgrade to?
