I tried to play earlier on wifi & it connected but it didn't have any readings on the geo map so it basically was a blank canvas (along with having the geo filter on but it didn't adhere to what I set at all) I ended up putting it on another country to see if I couldn't find a lobby but I still did & I even waited 2 mins but I guess it doesn't register the wifi for a Series S on Geo Filter
Double check the IP on the console, does it match the IP of the device you think it is on the Device Manager? Did you add it to the Geo-Filter after the console/game was already on? If so that could be another reason, follow this process and see if it works:
  1. Quit the application/game/client completely
  2. Remove device from the Geo-Filter
  3. Give PC PlayStation Device Type in the Device Manager (if on PC)
  4. Resync from the Geo-Filter Map menu
  5. Re-add the device to the Geo-Filter with the manual option
  6. Set up the Geo-Filter how you like
  7. Wait 2 minutes
  8. Boot up application/game/client
It seems to be working now but on the laptop advice is it not able to read accurately for the map UNLESS its labeled as a gaming console? Or did you just mean to set it as that if I was gaming on PC?
If you're gaming on a PC then set it as that yes, otherwise no need for the device you're viewing with
So if I wanted to game on PC I'd need to change the PC in device manager to either gaming console, playstation or xbox?
For the most compatibility yes that's what I'd recommend
