Helo,
I have a 900/200mb fiber optic internet.
I have a modem with R2 in addition to RJ45 cables.
The cable to the PC comes out of the R2 and the speed is satisfactory (700mb+).
Unfortunately, even if I put the phone on R2 to a maximum speed of 20mb.
I have a division into 2.4GHz and 5GHz.
It works the same on each.
And I have the settings set to automatic.
DumaOS: 3.3.280
Welcome to the forum!
Try this and see if it improves
  1. Use a WiFi analyzer to find the least congested channel and change to that
  2. Experiment with the widths to see what gives better results
  3. Ensure it's in an elevated position - not on a metal surface
  4. Ensure there aren't any electrical / wireless devices e.g headphones etc within close proximity ~3 feet if possible
  5. Set the antennae to this position _ | | _
  • 2 weeks later...
1. Still to the same
2. Still to the same
3. Wooden cabinet
4. TV ~60cm up | PS5 ~100cm
5. Different antenna settings do nothing.
The Wifi speed from the modem, which is in another room, in a wall enclosed by a metal box, is much faster than I am 10cm from r2.
Combining 2.4GHz and 5GHz into one network also does nothing.
Of course, this is not a problem of one device, but of all.
You know a modem doesn't give wifi bud 😂 That would be a router/modem combo are you by chance running bridged mode? Because if you aren't and it coming from router/modem combo I believe that might be your issue to fix that you would have to enable the bridge settings in the router/modem combo gateway
@DARKNESS
I might have worded it wrong, unfortunately I'm using a translator 😁
Fiber optic cable goes to my apartment, which is connected to Halny HL-4GMV3.
My operator does not give access to it - it is blocked.I have R2 connected to it.Both have different WiFi networks configured.
Hm I've had in the past had some issues with the wifi speeds for the R2 and it was based on the MHz/channel widths it can be possible that it something causing interference since as you said you are able to get the speeds when connected through lan so it must be something...make sure the head-ends for the antenna are well tightened
Do you have hybrid vpn enabled? if so disable it..it does lock speeds to 20mbs
Have you hard reset?
Also if your able to find the issue the speeds for wifi will be limited to 250mbs that just hardware limitation as is the hybrid vpn
Changing the widths did not change your speeds whatsoever?
Go to the Device Manager click the :menu icon then do a WiFi scan please and copy and paste the output here.
@DARKNESS I have hybrid vpn turned off
@Netduma Fraser
Once it made it worse, other settings didn't make it better as it is.
WiFi Scan:
wlan0:
BSS 54:db:a2:12:0c:c9(on wlan0)
    TSF: 1497523917196 usec (17d, 07:58:43)
    freq: 2462
    beacon interval: 100 TUs
    capability: ESS (0x0411)
    signal: -67.00 dBm
    last seen: 460 ms ago
    SSID: TELKAB_WIFI_120cc8
    RSN:     * Version: 1
         * Group cipher: CCMP
         * Pairwise ciphers: CCMP
         * Authentication suites: PSK
         * Capabilities: 1-PTKSA-RC 1-GTKSA-RC (0x0000)
    HT capabilities:
        Capabilities: 0x11ee
            HT20/HT40
            SM Power Save disabled
            RX HT20 SGI
            RX HT40 SGI
            TX STBC
            RX STBC 1-stream
            Max AMSDU length: 3839 bytes
            DSSS/CCK HT40
        Maximum RX AMPDU length 65535 bytes (exponent: 0x003)
        Minimum RX AMPDU time spacing: 4 usec (0x05)
        HT RX MCS rate indexes supported: 0-15, 32
        HT TX MCS rate indexes are undefined
    HT operation:
         * primary channel: 11
         * secondary channel offset: below
         * STA channel width: any
BSS 54:db:a2:12:0a:49(on wlan0)
    TSF: 1295877470790 usec (14d, 23:57:57)
    freq: 2462
    signal: -64.00 dBm
    last seen: 326 ms ago
    Information elements from Probe Response frame:
    SSID: TELKAB_WIFI_120a48
    HT capabilities:
        Capabilities: 0x1ac
            HT20
            RX HT20 SGI
            TX STBC
            RX STBC 1-stream
            No DSSS/CCK HT40
    HT operation:
         * secondary channel offset: no secondary
         * STA channel width: 20 MHz
    RSN:     * Version: 1
BSS 54:db:a2:03:db:f1(on wlan0)
    TSF: 1474184294792 usec (17d, 01:29:44)
    freq: 2462
    signal: -73.00 dBm
    last seen: 309 ms ago
    SSID: TELKAB_WIFI_03dbf0
    RSN:     * Version: 1
    HT capabilities:
            HT20/HT40
            RX HT20 SGI
            RX HT40 SGI
            TX STBC
            RX STBC 1-stream
            DSSS/CCK HT40
    HT operation:
         * secondary channel offset: above
BSS 54:db:a2:03:df:51(on wlan0)
    TSF: 1240355226001 usec (14d, 08:32:35)
    freq: 2462
    signal: -86.00 dBm
    last seen: 379 ms ago
    SSID: TELKAB_WIFI_03df50
    RSN:     * Version: 1
    HT capabilities:
        Capabilities: 0x1ac
            HT20
            RX HT20 SGI
            TX STBC
            RX STBC 1-stream
            No DSSS/CCK HT40
    HT operation:
wlan1:
BSS 54:db:a2:12:0a:4a(on wlan1)
    TSF: 1295861208295 usec (14d, 23:57:41)
    freq: 5200
    capability: ESS (0x0111)
    signal: -77.00 dBm
    last seen: 2730 ms ago
    SSID: TELKAB_WIFI_5G_120a48
    RSN:     * Version: 1
         * Capabilities: 1-PTKSA-RC 1-GTKSA-RC MFP-capable (0x0080)
         * 0 PMKIDs
         * Group mgmt cipher suite: AES-128-CMAC
    HT capabilities:
        Capabilities: 0x1ef
            RX LDPC
            HT20/HT40
            RX HT20 SGI
            RX HT40 SGI
            TX STBC
            RX STBC 1-stream
            No DSSS/CCK HT40
    HT operation:
         * primary channel: 40
    VHT capabilities:
        VHT Capabilities (0x33c179b1):
            Max MPDU length: 7991
            Supported Channel Width: neither 160 nor 80+80
            RX LDPC
            short GI (80 MHz)
            TX STBC
            SU Beamformer
            SU Beamformee
            +HTC-VHT
            RX antenna pattern consistency
            TX antenna pattern consistency
        VHT RX MCS set:
            1 streams: MCS 0-9
            2 streams: MCS 0-9
            3 streams: not supported
            4 streams: not supported
            5 streams: not supported
            6 streams: not supported
            7 streams: not supported
            8 streams: not supported
        VHT RX highest supported: 780 Mbps
        VHT TX MCS set:
            1 streams: MCS 0-9
            2 streams: MCS 0-9
        VHT TX highest supported: 780 Mbps
    VHT operation:
         * channel width: 1 (80 MHz)
         * center freq segment 1: 42
         * center freq segment 2: 0
         * VHT basic MCS set: 0xfffa
BSS 54:db:a2:12:0c:ca(on wlan1)
    TSF: 1497517056068 usec (17d, 07:58:37)
    freq: 5500
    signal: -85.00 dBm
    last seen: 2023 ms ago
    SSID: TELKAB_WIFI_5G_120cc8
    RSN:     * Version: 1
         * 0 PMKIDs
    HT capabilities:
        Capabilities: 0x1ef
            RX LDPC
            HT20/HT40
            RX HT20 SGI
            RX HT40 SGI
            TX STBC
            RX STBC 1-stream
            No DSSS/CCK HT40
    HT operation:
         * primary channel: 100
    VHT capabilities:
            RX LDPC
            short GI (80 MHz)
            TX STBC
            SU Beamformer
            SU Beamformee
            +HTC-VHT
        VHT RX MCS set:
            1 streams: MCS 0-9
            2 streams: MCS 0-9
        VHT TX MCS set:
            1 streams: MCS 0-9
            2 streams: MCS 0-9
    VHT operation:
         * center freq segment 1: 106
Thanks for that, set all the channels and widths to automatic, apply, reboot the router from the interface, wait 2 minutes then access and do a speedtest
@Netduma Fraser
I did as you wrote, the problem is still there.
These are my results on the 2.4GHz network - 2 meters from R2:
353138821_6341898005899262_7064352939307174975_n.thumb.jpg.9b84368648f46cae2cf47ccd203c0347.jpg348378838_777966824008738_7736213513743664256_n.thumb.jpg.3041cfab8205ab92b425c7893c5643a1.jpg
5GHz -same distance:
348378307_1615544418964985_2304549096285793330_n.thumb.jpg.6083723e0f1cf029adc12fb487745d6f.jpg348380356_281548814231671_6497917096407004234_n.thumb.jpg.e723194c6778481121e9306479a6c892.jpg
This is very strange, are you getting the same low speeds on other WiFi devices?
The speedtest on the router is from the router so won't change much whichever device/connection method you do it on.
I have uploaded R2 version 3.3.501
I did a factory reset after the update.
The best speeds now with the 2.4GHz & 5GHz mirror settings.
Default settings:
2.4GHz : Channel 6 & 40MHz
5GHz: Channel 44 & 80MHz
At the same time, my steamdeck shows a speed above 100mb.
Whereas the iPhone ~ 15.
It's much better, but still weak, and changing the wifi settings reverts to a maximum of 15mb on each device.
For now, I'll have to settle for this, if anyone has any additional advice, I'd be glad to share it.
Thank you for your help so far.
Interesting, on the iPhone if you disable the Private/Random MAC option for the WiFi does that improve the speeds after a restart?
