Administrators Netduma Fraser Posted April 21, 2023 Administrators Posted April 21, 2023 It's likely that you're actually playing on a server as it's a server based game and it's misclassified on the map as a peer, if you can provide the ID we can resolve that
Wantox81 Posted April 21, 2023 Author Posted April 21, 2023 6 hours ago, Netduma Fraser said: It's likely that you're actually playing on a server as it's a server based game and it's misclassified on the map as a peer, if you can provide the ID we can resolve that I enclosed the servers to try to prevent the peer-to-peer connection in efootball23 "friend rooms", where friendly matches are played, and force him to be redirected to the server, but as you can see in the pictures, unfortunately, the forcing did not work.
Wantox81 Posted April 21, 2023 Author Posted April 21, 2023 @Netduma Fraserin this picture the last bufferbloat test done from pc with LAN cable and QoS enable (Always). Is there any setting I can change in the router that would allow me to remove the triangle right on "Low Latency Gaming"? Thank you
Administrators Netduma Fraser Posted April 21, 2023 Administrators Posted April 21, 2023 Ahh I see, you won't be able to force with Ping Assist enabled so set that to 0 and see if you have better luck then. I think it's given you the triangle as it recorded a max ping as one point of 100 but looks like the overall result is good so I don't think you need to worry Wantox81 1
Wantox81 Posted April 24, 2023 Author Posted April 24, 2023 On 4/22/2023 at 1:09 AM, Netduma Fraser said: Ahh I see, you won't be able to force with Ping Assist enabled so set that to 0 and see if you have better luck then. I think it's given you the triangle as it recorded a max ping as one point of 100 but looks like the overall result is good so I don't think you need to worry I have been able to force server ping assist to zero and I have also been able to improve my bufferbloat by making a small change to the download percentage from 70% to 60% in qos, what do you think my friend?
Administrators Netduma Fraser Posted April 24, 2023 Administrators Posted April 24, 2023 Looks very good, can't get better than that!
Wantox81 Posted April 25, 2023 Author Posted April 25, 2023 16 hours ago, Netduma Fraser said: Looks very good, can't get better than that! When I change qos settings, do I then need to restart the router? Thank you for your support 🙏👏
Administrators Netduma Fraser Posted April 25, 2023 Administrators Posted April 25, 2023 6 hours ago, Wantox81 said: When I change qos settings, do I then need to restart the router? Thank you for your support 🙏👏 No you don't need to, they'll apply immediately, you're very welcome! Wantox81 1
Wantox81 Posted April 26, 2023 Author Posted April 26, 2023 21 hours ago, Netduma Fraser said: No you don't need to, they'll apply immediately, you're very welcome! Hello guys, how can i tell if qos (always) is working? Having limited the 500mbit bandwidth to 60% and given each device a maximum of 8%, if I do a speedtest the maximum down speed should be 24mbit? If it should be higher, does that mean the qos is not working? Another question: I did the ping optimizer test from the app and when I finished it moved the download percentage from 60% to 100%, so will the qos continue to work or will it automatically disable itself? Thank you so much
Administrators Netduma Fraser Posted April 27, 2023 Administrators Posted April 27, 2023 On 4/26/2023 at 12:48 PM, Wantox81 said: Hello guys, how can i tell if qos (always) is working? Having limited the 500mbit bandwidth to 60% and given each device a maximum of 8%, if I do a speedtest the maximum down speed should be 24mbit? If it should be higher, does that mean the qos is not working? Another question: I did the ping optimizer test from the app and when I finished it moved the download percentage from 60% to 100%, so will the qos continue to work or will it automatically disable itself? Thank you so much With Share Excess enabled on Bandwidth Allocation devices will be able to exceed their allocation if they need it so you'll see speeds up to the Congestion Control limit and so you'll know it's working if that is the limit. We're still improving that feature so if it puts it to 100% Congestion Control won't be doing much so best to manually change it for the moment. Wantox81 1
